Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Cat 60
this thread has 16 replies and has been viewed 1754 times
Old 10-29-2016, 06:30:25 PM
Bryant Bryant is offline
Default Cat 60
Did they a factory dozed blade for a cat 60? Has a tag that says Euclid and the pump has Euclid cast in it. Maybe a aftermarket part?
The Following 4 Users Say Thank You to Bryant For This Post:
Old 10-30-2016, 07:55:42 AM
Gene Williams Gene Williams is offline
Default Re: Cat 60
I would say aftermarket but a nice setup compared to others
The Following User Says Thank You to Gene Williams For This Post:
Old 10-30-2016, 10:04:31 AM
Default Re: Cat 60
The Cat 60 was one of the first crawlers to be turned into Dozers. I remember seeing Cat factory photo of a 60 pushing dirt out in the California mountains building the original Mulholland Drive. I have never seen this Euclid unit but as mentioned it is a very modern balanced unit. Ive included pics of Will Wingos Cat 60 with a blade. It has a single hyd. cylinder in the rear that pushes the blade up and down through a pivot located at mid track. These pics were taken at the national Historical Equip. Assoc show in 2011. Will is from PA and hauls this tractor all over to country. I have a similar blade that came with a Cat 30 and is very similar to Will's tractor. It took a few years until Cat got on board and began producing their own integrated dozer setups. It sort of reminds me of how BO Linderman turned early JD's into crawlers and were taken over when JD saw how effective they were. Ed B
ID:	266867   Click image for larger version
The Following 4 Users Say Thank You to Ed Bezanson For This Post:
Old 10-30-2016, 10:40:42 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Default Re: Cat 60
Also note the differences between the different makes of blades as to the shape of the curvature of the blade. It took a few tries to learn that the blade should scour similar to a plow mouldboard to push easier.
Old 10-30-2016, 05:01:11 PM
Default Re: Cat 60
Just remembered that one of the first builders was La Plant-Choate. I would also like to see the other side of this machine because all the Hydraulic equip is on that side. Looks like a rock shaft goes across just behind the radiator on the frame. Thanks Ed B
The Following User Says Thank You to Ed Bezanson For This Post:
Old 11-03-2016, 07:32:10 PM
Default Re: Cat 60
Here are some pictures. Where is the serial number located at on the frame?
The Following 2 Users Say Thank You to Bryant For This Post:
Old 11-03-2016, 07:34:26 PM
Default Re: Cat 60
Another one
The Following User Says Thank You to Bryant For This Post:
Old 11-03-2016, 07:36:48 PM
Default Re: Cat 60
One more picture
Old 11-03-2016, 07:40:08 PM
Default Re: Cat 60
The last picture
Old 11-14-2016, 10:23:25 PM
JasonPayneCrawlers JasonPayneCrawlers is offline
Default Re: Cat 60
What is the serial number ?
The Following User Says Thank You to JasonPayneCrawlers For This Post:
