Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
DG cletrac starter
this thread has 7 replies and has been viewed 584 times
Old 07-17-2017, 12:40:32 PM
Alltractorman Alltractorman is offline
EMAIL NOT WORKING
Images: 21
Default DG cletrac starter
What starter was on the DG? I need to find one...one that would fit. Doesn't need to be original. Also are manifolds being made for them? Thanks
Old 07-17-2017, 02:42:58 PM
ehpower2 ehpower2 is offline
Default Re: DG cletrac starter
I checked my books and while i do not have the DG model listed it appears that most of them seemed to use an autolite MZ style starter so hopefully that helps you out or at least points you in the right direction
Old 07-18-2017, 12:14:42 AM
EMAIL NOT WORKING
Images: 21
Thanks...the starter I have that was on it is a Delco. It is to far gone to fix....but the tag is messed up
Old 07-18-2017, 11:30:16 PM
For all things Cletrac (parts, advice, sympathy) start with Landis Zimmerman olivercletrac.org (or was it .com and the forum cletrac.org??)...
A Bg-Warner ign catalog does show DG (no years) with Delco dist, gen and starter, but lumps a bunch of models together under starters...
Old 07-21-2017, 11:02:11 PM
EMAIL NOT WORKING
Images: 21
Yeah I had called but they want $400 for a starter. I don't need original. There has to be something out there that would fit. Guess I will just keep lookn. Thanks for the info guys..
Old 07-22-2017, 11:00:36 AM
Pauls Welding Minnesota Pauls Welding Minnesota is offline
Do you know if it has a Hercules engine in it ?
---------- Post added at 10:00:36 AM ---------- Previous post was at 09:21:47 AM ----------
found my old Delco tractor equipment catalog, looks like Cletrac used the Hercules in about all of them so if I know what Herc engine can give you a Delco starter #.
Old 07-22-2017, 02:13:46 PM
My old catalogs seem to mostly agree came with RXC 45/8x51/4, altho one (of six) listed the RXB 41/2x51/4...
Could also've been repowered during its life; some of these Herc series were made to be drop-in fits for each other...
Old 07-22-2017, 02:18:13 PM
if you got a fitting but dead starter, just bring it into a good starter shop. They can almost certainly fix it, and likely for a lot less then 400 bucks.
Cletrac DGH Tom Madden Dozers and Crawlers 0 07-12-2017 04:48:17 PM
Interesting comparison Onan J series starter & GM starter Tracy T Onan Generators 5 02-16-2016 10:33:04 PM
Cletrac. Alexbpeterson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 08-03-2012 05:38:40 PM
cletrac bg j ridings Antique Farm Tractors 0 08-15-2010 09:47:23 PM
Cletrac: where to from here. Mtype Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 05-07-2006 11:07:31 AM
