Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
1/2 scale Sorg engine
this thread has 10 replies and has been viewed 1431 times
Old 12-15-2018, 10:15:26 PM
Marv in Minn's Avatar
Marv in Minn Marv in Minn is offline
Default 1/2 scale Sorg engine
about 12 years ago, i saw some old pics of a Sorg engine in the back of a pickup in Wisconsin.
since then the whereabouts of this engine is a mystery.
the interesting design of the Sorg is that the piston is stationary
and the cylinder moves guided in a crosshead layout.
the pics had a 1" paint brush on the base.by scaling those pics
and an article in the May 1912 Cosmopolitan magazine, i started drawing
and had 2 frame castings made.
the head, cylinder, crosshead, connecting rod, etc are machined from solids.
the model sat for about 10 years and after some encouragement, (yes, they were bugging me )
this fall i got back working on it. not running yet but getting closer.
i'll start with a couple of the pics and the Cosmopolitan ad.
ID:	324502   Click image for larger version
Name:	Engine Sorg Left.jpg
ID:	324503   Click image for larger version
Name:	Engine Sorg Rear Close.jpg
ID:	324504   Click image for larger version
restoring old iron, hot air engines and modelmaker.
The Following 8 Users Say Thank You to Marv in Minn For This Post:
Old 12-15-2018, 10:23:19 PM
Default Re: 1/2 scale Sorg engine
a start and how it sat for 10 years
ID:	324509   Click image for larger version
ID:	324510   Click image for larger version
ID:	324511   Click image for larger version
The Following 6 Users Say Thank You to Marv in Minn For This Post:
Old 12-15-2018, 10:32:47 PM
this is how it sits now. the cooling system pumps the water into the bottom of head,
thru the piston, back thru the head and out.
the mixer is based on a Wyvern model engine design.
ID:	324513   Click image for larger version
ID:	324514   Click image for larger version
ID:	324515   Click image for larger version
Old 12-16-2018, 12:20:54 AM
LCJudge LCJudge is offline
Marv, so glad you've almost got that thing done for me.....
Tommy Turner
The Following User Says Thank You to LCJudge For This Post:
Old 12-16-2018, 01:13:51 PM
ChipTosser ChipTosser is offline
Thumbs up Re: 1/2 scale Sorg engine
Beautiful work!
I can't wait to see it run.
The Following User Says Thank You to ChipTosser For This Post:
Old 12-16-2018, 01:32:02 PM
Geikenr49 Geikenr49 is offline
I am really excited to see this finished and running
The Following User Says Thank You to Geikenr49 For This Post:
Old 12-17-2018, 10:38:25 AM
Mitch Malcolm Mitch Malcolm is offline
Outstanding craftsmanship !!! Marv It will be cool to see run.
The Following User Says Thank You to Mitch Malcolm For This Post:
Old 12-20-2018, 10:55:57 PM
Bill Schaller Bill Schaller is offline
Marv, if it wasn't for all the other stuff I know you got done in the meantime, I would think you work down at my speed.
The Following User Says Thank You to Bill Schaller For This Post:
Old 12-21-2018, 07:43:59 AM
yes i do have a tendency to get side tracked
Old 12-22-2018, 03:22:06 PM
Great job Mary! I have seen a lot of things done to skirt patent limitations, but that engine takes it to the limit for sure! I wonder how many were actually produced, and if they were successful? keep us advised as for your progress!
Old 02-21-2019, 12:12:14 PM
KarlZ KarlZ is offline
This is great! I remember you displaying a mock-up or prototype of this at the NAMES show many many years ago. I was hoping it would resurface once again!
Best of luck and I'm looking forward to following your posts on this.
Karl
The Following User Says Thank You to KarlZ For This Post:
Scale OilPull Build - About 3/8 Scale of a Heavyweight decoy64 Scale Model Engineering 22 04-26-2019 10:03:55 PM
SORG engine mystery John Merry Hit & Miss Gas Engine Discussion 23 12-18-2018 01:27:03 PM
Scale Sorg Engine Model KarlZ Scale Model Engineering 6 05-30-2011 11:45:55 AM
1/2 scale 1/3 scale steam engine Dale Steam Stationary Engines, Traction Engines 5 10-16-2006 10:06:03 AM
1/2 scale Kitten Steam engine/1/4 scale case KG1584 Steam Stationary Engines, Traction Engines 9 07-21-2006 12:21:43 AM
