Galloway compression release
this thread has 11 replies and has been viewed 2120 times
Closed Thread
Old 01-11-2005, 01:16:44 PM
Dale S Dale S is offline
Default Galloway compression release
I've read that on the Galloway engine you need a compression / check valve.What have people used in this application?
Old 01-11-2005, 07:50:43 PM
Randy Wells's Avatar
Randy Wells Randy Wells is offline
Talking Re: Galloway compression release
Dale, I'm not sure if you need a relief valve but I know that my 2 1/2 hp Galloway has one. I have seen them on others such as 5 hp and up.
I hope this helps.
Randy
Old 01-11-2005, 07:59:35 PM
Wink Re: Galloway compression release
I'll post a picture soon of mine. I am using a priming cup with a elbow.
Randy
Old 01-11-2005, 08:18:09 PM
Gasengin Gasengin is offline
Default Re: Galloway compression release
On my 6 hp, I used a brass 1/4 turn drain vavle. No check valve and not sure why you would need one. Sometime I open and sometimes I forget. I'm not sure what they had originally.
Old 01-11-2005, 08:49:15 PM
Dale, here is a picture of what I am using. It is loose fitted in the picture.I am presently restoring this Galloway.
Old 01-11-2005, 08:51:59 PM
Photo Re: Galloway compression release
Sorry about that
Old 01-12-2005, 08:17:38 PM
Al Wait Al Wait is offline
Galloway used a brass right angle valve, sort of like a sillcock (outdoor water valve) without the threaded part to attach a water hose. 3/8" pipe. Al Wait
Old 01-12-2005, 08:42:29 PM
Whatever you use, I would not point it up unless you never use it. There is oil and exhaust that comes out when the engine fires. This would end up all over the nice paint job on the water hopper (or anything else above the engine). I'll going to try to find the type that points down for mine.
Old 01-12-2005, 09:04:51 PM
JCullom's Avatar
JCullom JCullom is offline
Al's right, here's somewhat of an example of what he's referring to...
Old 01-12-2005, 09:27:51 PM
Jim Sherman's Avatar
Images: 84
Here are some pictures of the originals (or what I beleive to be originals) on my 5HP & 6HP Galloway engines.
Old 01-12-2005, 09:28:41 PM
Images: 84
2 more pic's of mine.
Old 01-12-2005, 10:45:56 PM
Roger Kirschenman Roger Kirschenman is offline
I use a compression releave vale from a old 2 cyl. John Deere A or B looks good & works good
Closed Thread
B&S Model B compression release Stevie Mote Small Air Cooled Gasoline Engines 11 11-14-2010 10:22:38 AM
Compression release R. Kern Antique Gas Engine Discussion 11 02-05-2008 10:28:04 AM
Compression release valve on 15 hp reid Jeff P Oil Field Engines 7 05-03-2006 05:39:15 PM
Briggs Model ZZ Compression Release Bill C. Small Air Cooled Gasoline Engines 2 11-07-2005 01:33:39 PM
Pick one: compression release or spark advance? Harold Hunt Kohler Generators 1 08-17-2004 10:50:45 AM
