Timming A Buzz Coil
this thread has 4 replies and has been viewed 1563 times
Old 01-27-2005, 02:53:00 PM
mhljr56 mhljr56 is offline
Default Timming A Buzz Coil
This Is My First Try To Time A Buzz Coil ,i Have Had A Dergwheel On Eng And Found Tdc And Placed 2 Line Up Marks I Neen To Know How To Set My Contack Im Am Useing A Pin In Flywheel And A Plastic Tap With A Wire On The End So I Have Some Adjustment When Dose The Wire Need Need To Hit The Pin And For How Long Max
Old 01-27-2005, 09:14:44 PM
Brent Brent is offline
Default Re: Timming A Buzz Coil
I would set it just passed TDC to stop kick back and longenough for about 2 inches of travel on the fly wheel . I think that will be a good start and adjust from there .
Old 01-27-2005, 10:00:08 PM
Junkologist's Avatar
Images: 129
It seems to me you would be better off trying to time your spark off the cam gear instead of the flywheel. You'd be sparking half the time and the battery would last longer. Just a thought. Every engine I've owned that used a buzz coil had one contact on the pushrod and another on the block with an indent on the cam to close them.
Mike
Old 01-28-2005, 11:34:14 AM
Thanks For The Reply , I Did Not Think Any One Was Going To Reply I Setting Last Night Thinking On This And Came To The Same Thing,it Would Be Bettery To Do Of The Cam Gear ,thi Is On A 5hp Ottawa And There Is Not Much Room At The Cam ,think I Might Look At The Mag Trip Arm Max
Old 01-28-2005, 11:37:00 AM
Thanks For The Reply ,i Think I Will Look At The Cam Or Mag Trip Rod Max
Buzz coil help John Rigter Antique Gas Engine Discussion 2 02-26-2005 02:28:30 AM
Buzz coil or auto coil Don Nelson Antique Engine Archives 5 12-07-2004 06:08:54 AM
buzz coil Oscar Allen Antique Engine Archives 2 06-03-2004 08:42:59 PM
Buzz Coil Value Robert in W. Mi Antique Engine Archives 12 01-29-2003 01:19:55 PM
BUZZ COIL A.J. TELOWICZ Antique Engine Archives 9 12-27-2002 10:05:59 PM
