Piston Stops
this thread has 1 replies and has been viewed 1134 times
Old 02-25-2005, 11:12:06 AM
Larry K Larry K is offline
Question Piston Stops
What is the general practice when encountering pistons that have stops? Does a person file the stops off or does one file the piston rings to accomodate the stops?
This is for an upright engine.
Larry Kastens
Old 02-25-2005, 04:12:53 PM
Chuck Woycke Chuck Woycke is offline
Default Re: Piston Stops
larry,if the engine is a 2 cycle you need the piston pins (stops) 2 cycle engines have ports that time the engine intake/exhaust .the pins keep the rings from rotating.if not used the end gaps will catch on the cylinder ports and will most likely break the rings.on 4 cycle engines some have the pins also i have found that you can file them off if you are putting new rings in.just make sure you stagger the ring gaps.for example if the piston has 3 rings make sure the ring gaps are a 120 degrees apart.they only use ring pins today on 2 cycle engines and low rpm diesel engines.it's pretty much a thing of the past.modern engines don't use them anymore.-chuck
Generator stops when start button released scubar Onan Generators 7 02-11-2008 06:48:32 PM
Onan BGE consistently stops running after a few minutes scubar Onan Generators 19 02-07-2008 03:54:32 PM
Lister D stops when warm goatfarmer Vintage Diesel and Oil Engines 11 02-25-2007 04:08:57 PM
engine stops Jesse Zilafro Antique Engine Archives 14 01-01-2002 03:05:33 PM
engine stops Jesse Zilafro Antique Engine Archives 0 12-31-2001 04:52:49 PM
