Fairbanks T Questions
this thread has 17 replies and has been viewed 2256 times
Old 02-25-2005, 11:17:53 AM
Larry K Larry K is offline
Question Fairbanks T Questions
Does anyone have a close-up view how the ignitor and pawls are situated on a Fairbanks T engine?
Secondly, if a rod dip system is employed, would one drill a hole in the rod so the oil could reach the bearing?
The engine I have has the "oil pump" but I an unable to unclog the hole in the crank without removing the outer cover and flywheel. The flywheel is seized and I would rather not try to remove it.
Thanks.
Larry Kastens
Old 02-25-2005, 03:04:23 PM
Daniel Dorece Daniel Dorece is offline
Default Re: Fairbanks T Questions
The FM T engines use four different igniters so first you need to figure out which one you have.
Dan
Old 02-25-2005, 03:24:35 PM
Question Re: Fairbanks T Questions
My 1915 four horsepower T is missing the ignitor. I have the mechanism with the pawl (sliding part) but not the ignitor. I thought I had the ignitor but it isn't there, so I will probably have to make one.
Thanks.
Larry Kastens
Old 02-25-2005, 07:21:11 PM
Images: 4
Larry,
I have read here on this forum and elsewhere that the Faribanks Morse T is the same as the Jack of all trades only it is on a cast iron base instead of skids or cart.
At anyrate here is a picture I just took of the igniter on my 1910 2hp Jack Of All Trades.
Dick
Old 02-25-2005, 07:32:15 PM
Dick Brown Dick Brown is offline
I have several of the model H horizontal jack of all trades and the vertical T engines. on mine all the ignitors will inter change.
hope this will help.
Dick
Old 02-25-2005, 07:43:42 PM
Smile Re: Fairbanks T Questions
Originally Posted by Dick Welty
Larry,
Dick
Thanks Dick and to the others who responded. I feel quite stupid as I found my ignitor soaking in a can of Kroil. It just goes to show that when a person doesn't get back to the project for a few months, his memory isn't perfect. However, I do appreciate the picture because it is the ignitor that I have and it shows how everything should be attached. Thanks and many Thanks to Harry for this site.
Larry Kastens
Old 02-25-2005, 07:43:57 PM
Images: 4
This ignitor and trip is on a 1907 3hp engine.
Old 02-25-2005, 07:45:14 PM
John Hammink's Avatar
John Hammink John Hammink is offline
An engine friend of me has this 2 hp 1902 FM. It has both an igniter and the hot tube.
Old 02-25-2005, 11:25:48 PM
Images: 4
Larry,
Isn't it funny that while all three igniters are very similar all three trips are quite different.
Dick
Old 02-26-2005, 06:21:26 AM
Ralph Leonard Ralph Leonard is offline
Dick, What is the oiler on left for? My 1905 don't have one
Old 02-26-2005, 11:28:30 AM
Elden DuRand's Avatar
Images: 6
This is a not-too-good blowup of a photo of the ignitor on my 1897 2-HP Jack of All Trades.
If you want to see more about this engine, go to:
http://home.cybertron.com/~edurand/F...-M%20Jack.html
Or the whole junky mess:
Take care - Elden
Old 02-26-2005, 04:48:29 PM
Dwight Vivas Dwight Vivas is offline
Hi Elden,
Great job on the Jack of all Trades !
Hope you're gonna bring it to Coolspring in June, their feature engine is
Fairbanks Morse. Don't worry about the flywheel, it look good just standing still.
Dwight Vivas
Matoaca, VA.
Old 02-26-2005, 10:38:49 PM
Images: 4
Ralph,
I just went out to look at my engine to see what the second oiler is for and saw that it is connected by a bracket that looks made up (not original) a 1/4" copper tube connects the oiler to a hole near the bottom of the side cover below the main bearing on the igniter side. I have not worked on this engine and have only had it a short time.
I never knew that it wasn't original as I have no manuals for this engine. Since it is lower than the main bearing I think that someone may have installed it to maintain an adequate oil level in the crankcase
NOTE:Edited 2-28-05 I just removed the screened crank case cover and looked into the crankcase. I saw that there is no oil pump in my engine. There is however a flat disk about the size of a 1 lb coffee can lid connected to the crank with a screw. This disk has a hole in the center that the crank goes through. The disk is very close to the inside of the igniter side crank shaft bearing plate. this disk has about a 1/4" cupped flange around its circumfrence. It appears that any oil that comes from the second oiler is probably slung by this disk around the inside of the crank case. I don't know why this is necessary as the connecting rod bearing cap splashes oil from the bottom of the crank case.
The next time I comunicate with the prior owner I'll ask him if he installed it and if so why?
I notice that there are 2 large crankcase ventilation cutouts covered with screen that might blow oil out of the crankcase at a rate faster than the main oiler can restore it seeing that the main oiler has to libricate the piston and maybe the wristpin before it falls into the crankcase.
Maybe some one else has a better answer.
Dick
Old 02-27-2005, 10:50:45 AM
Images: 6
Originally Posted by Dwight Vivas
Hi Elden,
Dwight Vivas
Matoaca, VA.
Dwight:
Thanks for the comments. Although I could show it just standing there, I like to show running engines. I -think- I have a good flywheel located but am not sure about transportation yet.
Once I get a good wheel on it, I may take it to some shows although the butt-buggy is a LOT of fun and I get to move around and see other folks' stuff and talk to 'em.
Coolspring sounds good but I'm not sure I can make that one.
Again, thanks and take care - Elden
Old 02-27-2005, 05:40:00 PM
James Elenbaas James Elenbaas is offline
In Larry's initial post he mentioned a "Oil Pump". I have a 1907 9 hp and 1910 4 hp and neither of these have a oil pump. Is this something that was added by Fairbanks Morse at a later date? How is it activated.?
Old 04-03-2005, 09:12:36 PM
[QUOTE=Dick Welty]Ralph,
___
I have learned that what you describe is the oil pump. There is a hole in the crankshaft that exits where the rod is attached. This lubricates the connecting rod. In my situation, the parts are there but the hole is plugged and I am unable to remove the flywheel, so I made an oil dipper to do the job.
Larry
Old 04-03-2005, 09:16:45 PM
The oil pump is described well by Dick Welty. The slinging action brings oil through the crankshaft where it exits underneath the connecting rod. I didn't know this until I received responses from others.
Thanks everyone for your responses.
Larry
Old 04-08-2005, 10:58:34 PM
john hamilton
The extra oiler and the disk on the crankshaft are found on Type T Special Electric engines. They have very heavy flywheels to keep a steady engine speed for electricity generation. The 1/4" tube should go from the oiler, thru the side plate, parallel to the crankshaft and drip into the disk he mentions. Centrifugal force carries the oil to the rim and there is an additional tube up to the hole in the web of the crank. The hole in the crank is 19/64" so the smaller tube fits right in.
Regular T's just used that little splasher on the bottom of the shaft to dip into the oil bath.
Thanks to everyone for writing about this engine.
Questions on Fairbanks Morse Shine Stringer Antique Gas Engine Discussion 10 10-03-2007 02:38:16 AM
Fairbanks Morse 3HP ZC Questions Alan James Antique Gas Engine Discussion 0 05-29-2007 03:55:28 AM
fairbanks za questions earniemanson Antique Gas Engine Discussion 3 10-12-2006 01:05:14 PM
Fairbanks questions Darryl Boyd Antique Engine Archives 0 09-21-2002 05:22:06 PM
More Fairbanks H questions scott Antique Engine Archives 8 01-07-2001 06:41:05 PM
