IHC LB Valve Cover
this thread has 2 replies and has been viewed 1134 times
Old 03-10-2005, 01:50:28 PM
Mike in NC's Avatar
Images: 64
Default IHC LB Valve Cover
What is the difference between a 1 1/2 - 2 1/2 HP and a 3 - 5 HP LB valve cover? Is the 3 - 5 wider? Thanks.
Old 03-10-2005, 05:25:28 PM
Andrew Albrecht's Avatar
Andrew Albrecht Andrew Albrecht is offline
Images: 72
Default Re: IHC LB Valve Cover
Mike; I beleive the 3-5 H.P. is Physicaly larger then the 1-1/2 - 2-1/2 h.p.
Not just wider, but bigger all around. And you also have two versions one has the small swing door on the side of the cover so you can get oil in the troff. and the other version does not have that but a tube on the bottom of the cover to catch any oil spillage and get it away from the engine.
I Get My Corn From A Jar
Old 03-10-2005, 06:22:40 PM
Mike in NC's Avatar
Images: 64
The one with the door is for an LA and the one with a tube is for an LB. I bought one that is the right width, but about an ince or so too long.
Rumely 20-35 Valve Cover D Rutherford Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 02-06-2008 12:46:19 AM
IHC-LB Valve Cover George Vaughan Antique Gas Engine Discussion 4 01-17-2008 10:18:09 PM
IHC LB valve cover bill jacobsen Antique Gas Engine Discussion 1 09-18-2007 11:19:25 AM
Cracked Valve Cover-Onan DJE B.Ikard Onan Generators 4 07-01-2007 02:27:10 PM
Gen. End Cover Bill Chason Generators & Motors General Discussion 0 11-28-2000 05:20:01 PM
