Hercules ? 1 3/4hp help and info
this thread has 16 replies and has been viewed 2027 times
Old 03-12-2005, 02:38:02 PM
RIRR
Photo Hercules ? 1 3/4hp help and info
Hello I have a Engine which I belive to be a Hercules. It is a 1 3/4S HP, 600 Rpm is what it says on the brass tag. The serial # is 865654. If anyone can tell me the year that would be great. It has spoked flywheels. And If I am even right on the brand thanks. Hopefully the picture worked.
Old 03-12-2005, 02:46:16 PM
Rex Pyles Rex Pyles is offline
Images: 7
Default Re: Hercules ? 1 3/4hp help and info
I am guessing that the serial# starts with a 3 and not an 8, if that is the case it's a 1928 model. There should be a casting date somwhere on base of the engine along the cylinder like 11-12-28 or something like that. Glenn Karch can clear up the rest. More than likely it's a Hercules because of the splash guard.
Old 03-12-2005, 03:15:16 PM
RIRR
Rex you are correct it is a 3 instead of a 8. thanks for you help.
Old 03-12-2005, 11:12:29 PM
Rob Skinner's Avatar
Rob Skinner Rob Skinner is offline
Your engine has the squared off hopper that Hercules installed on engines they built for other companies. If the current color is similar to the original, then it's probably a Jaeger. Jaeger built cement mixers and purchased some of their engines from Hercules.
Rob
Old 03-12-2005, 11:25:46 PM
BobRR BobRR is online now
Were has Glen been lately? Havent seen any post's from him! Is he doing OK?BobRR
Old 03-12-2005, 11:29:28 PM
Gasengn Gasengn is offline
At that serial number, all brands of Hercules built engines used the same block. Being rated at 1 3/4 HP, that rules out Jaeger and ARCO which were rated at 2 HP. That leaves Hercules and Economy. A crank guard indicates Hercules. In 1928 Sears started selling the XK rather than the S model engines. Look for a casting date above the spark plug on the block or sometimes it will be on the opposite side of the block. That is the casting date - not when the engine was completed which could have come several months later.
Old 03-13-2005, 01:05:50 AM
It's time I went back and read the book again!
Old 03-13-2005, 08:11:20 AM
Images: 7
RIRR, here is a picture of a 1 3/4hp Hercules that I had......wish I still had it
Old 03-13-2005, 08:23:19 AM
RIRR
Rob the color is not original I picked up two enginges from a fellow and they were both painted the same color . Rex nice engine . I also am wondering what color the engine is supossed to be. I am stripping it down today hopefully I will find some old paint under there. Thanks for everybodys help to this point.
Old 03-13-2005, 09:04:50 AM
Images: 7
John Deere green is what most people use.
Old 03-13-2005, 12:57:04 PM
RIRR
The date I found on the block were 3-15-28. Another # I also found a PAT date of OCT 30 1923. When I stripped the block, head and Flywheels today I found quite a bite of red paint under the blue paint. Which is leading me to belive it is a Economy. But still not shure.
Old 03-13-2005, 02:44:49 PM
Images: 7
Econ's did not have a splashguard unless it got by somebody in the factory. also Glenn mentioned earlier that Sears started selling a different style in 28.
Old 03-13-2005, 06:10:28 PM
RIRR
Rex do you know if a Economy have the holes in the back for a splash guard like a Hercules. Could of somebody put it on later or maby it was a option? Or if used indoors maby the splash guard was a option.
Old 03-13-2005, 08:20:09 PM
Images: 7
This is answer but it might not be right.
Old 03-13-2005, 10:54:36 PM
RIRR
Rex, I came across the answer I think. All parts were completely stripped to bare metal today. Under all the blue paint was red paint except when it came to the splash guard. It was painted black but under the black was the answer. It was green like a Hercules. Also at the hopper by where the decal goes was a very very faded decal which looked to be the size of a Ecomony decal. Not round like a Hercules. So it looks to be a Economy engine that for some reason someone bolted a Hercules splash guard on for one reason or another through the years. So thank you for your help and everyone elses I think it is solved.
Old 03-13-2005, 10:57:12 PM
Economy engines normally did not have holes in the back for a crank guard. A crank guard is never listed as an option in the Economy literature for the E through S models. However, an enterpising person could drill and tap holes and add a Herc guard.
Old 03-17-2005, 11:08:18 AM
Rick Strobel's Avatar
Rick Strobel Rick Strobel is offline
Images: 20
Here's my 1 3/4 S. I call it a Herc, but it's an Economy.
http://community.webshots.com/album/204171586dXMcJZ
RickinMt.
Silver King or AXB Hercules Engine info BobM Antique Farm Tractors 6 09-25-2007 12:33:20 PM
Hercules 2 1/2 info needed anthony brinson Antique Gas Engine Discussion 3 09-25-2006 09:17:30 PM
Hercules 5HP Value ??? silveraven Antique Gas Engine Discussion 12 09-18-2005 07:48:15 PM
Hercules info dwight Antique Engine Archives 4 04-13-2000 05:32:43 PM
Info on large Hercules V8 Dave Lytle Antique Engine Archives 1 03-19-2000 11:58:53 PM
