Model T coil question
this thread has 4 replies and has been viewed 1529 times
Old 03-31-2005, 05:42:54 PM
Benny Mckheean Benny Mckheean is offline
Default Model T coil question
If setting the amp's on a Model T coil using a 12v battery would you set them at half the 1.3 amps that you use for a six volt battery.Thanks all
Old 03-31-2005, 09:18:07 PM
Bob Ronning's Avatar
Bob Ronning Bob Ronning is offline
Images: 4
Default Re: Model T coil question
I don't know what amps to set them at but I would set it the same for 6 v. or 12 v. On a model T ford you start the car on 6 v. then change to the mag. and it can get up to 18 volts on the mag. I have always adjusted the coil for the best and strongest buss Bob.
Old 04-01-2005, 02:01:54 AM
Images: 17
Benny: I would still set them at 1.3 amps. Setting them with more amps to get a bigger, brighter, spark, just burns the ponts. Any body got a source for just the tungeston part of the points ?
Did you make a new friend today, and a lot. Paul - "OLDIHC"
Old 04-01-2005, 02:15:38 AM
BWegher BWegher is offline
Buzz coil makers told customers to adjust the coil to the minimum current required to run the engine.
Old 04-01-2005, 02:21:10 AM
Ken Majeski's Avatar
Images: 42
Thats one Funny thing about the T coil.... Voltage doesn't seem to make much difference as far as current draw is concerened. You can set one at 6 volts and then hook it to 12 volts and the draw will be about the same probably due to the vibrating nature of the points. The T or the Fordson magneto in good shape will generate as much as 35 to 40 volts AC at high speed...
Ken Majeski, Ellsworth Wis.
Model "BUZZ" coil ZZZAAAPPP for a model engine Paul Spence Magnetos, Ignition Coils and Spark Plugs 5 02-22-2015 10:36:08 AM
model T coil Mac Leod Antique Engine Archives 7 06-14-2004 10:46:31 AM
Not Model T Coil Question Benny Mckheean in NC Antique Engine Archives 4 09-28-2003 11:25:11 AM
Model T Coil Benny Mckheean in NC Antique Engine Archives 5 08-30-2003 03:45:43 PM
Model T coil Craig Kopsell Antique Engine Archives 9 09-02-2001 06:00:22 PM
