Needle valve packing
this thread has 3 replies and has been viewed 1832 times
Old 04-20-2005, 02:01:00 PM
Dale S Dale S is offline
Question Needle valve packing
What do you guys use to replace the felt type packing in a needle valve on a mixer?
Old 04-20-2005, 02:38:16 PM
Harvey Teal Harvey Teal is offline
Default Re: Needle valve packing
I use Teflon/asbestos string where trying to keep things original. For engines that I actually use, I use a small o-ring around the screw, and a knurled thumb nut to tighten against the o-ring. This eliminates springs, leakage, etc.
Old 04-21-2005, 01:06:30 AM
Exclamation Re: Needle valve packing
If the screw has a packing nut, either the teflon or some graphite impregnated packing material works well. The graphited packing is available from a good plumbing supply house.
Old 04-21-2005, 10:01:52 AM
Elden DuRand's Avatar
Images: 6
If it's just to seal a screw thread, I'd use some cotton twine. With the small amount of wear, it will hold up fine and won't be affected by the fuel.
Take care - Elden
http://home.cybertron.com/~edurand
Needle Valve Packing Material Tim0477 Onan Generators 0 03-20-2007 04:45:02 PM
Need valve packing material Dave Mcadams Antique Engine Archives 5 06-26-2004 12:01:57 PM
Jam Nut on Needle Valve? Baggsy-Wy Antique Engine Archives 3 11-14-2003 12:56:54 PM
Needle valve Alan James Antique Engine Archives 0 02-06-2003 12:38:09 PM
needle valve packing Bruce Antique Engine Archives 1 01-27-2002 10:08:34 AM
