Fairbanks Z type D "salt block Magneto
this thread has 3 replies and has been viewed 1733 times
Old 04-29-2005, 11:49:30 AM
Dan Donaldson's Avatar
Dan Donaldson Dan Donaldson is offline
Default Fairbanks Z type D "salt block Magneto
Does the end of the shaft on a F-M Z Type D "salt block" have a gear on it or is it a coupling? A friend of mine wants to work on the mag. of his engine but is afraid to remove it if it has a gear on the shaft.
Dan Donaldson
Old 04-29-2005, 11:55:56 AM
Bohunk Bohunk is offline
Default Re: Fairbanks Z type D "salt block Magneto
There is a gear on the end of the Mag
Old 04-29-2005, 12:14:22 PM
Neale Behm Neale Behm is offline
Images: 2
Timing is pretty simple. Allign the hash mark on the flywheel with the seam for the block and crankcase cover (about the 10 o'clock position when facing the flywheel). Rotate the gear on the magneto until the arrow on the side of the magneto gear is visible through the hole in the block opposite the magneto when the teeth are meshed.
Thanks Harry
Old 04-30-2005, 09:44:14 AM
Thanks for the info Bohunk and Neale.
Dan
Fairbanks "D" Salt Block Question??? Shane Ball Antique Engine Archives 2 03-29-2004 07:00:24 PM
Fairbanks "Salt Block" Steve Sewell Antique Engine Archives 6 10-15-2003 04:46:24 PM
Need help with Fairbanks 6hp, Type "R" Magneto Dave Newman Antique Engine Archives 10 09-12-2003 07:09:35 AM
Fairbanks-Morse Type "R" Magneto Questions Ron Vance Antique Engine Archives 2 01-10-2002 06:06:52 AM
Fairbanks "D" Salt Block Rod Bearing? S.B. Antique Engine Archives 1 11-04-2001 10:21:11 PM
