Throttle Gov. IHC M Running Poorly
this thread has 2 replies and has been viewed 1034 times
Old 05-22-2005, 08:38:43 AM
W. Bittle W. Bittle is offline
Question Throttle Gov. IHC M Running Poorly
This may be an easy one for someone with a good amount of experience with IHC throttle goverened M's .... this has happened on a spark plug version and now on an ignotor version I am working on. Both of these engines miss occasionally without load. In one case I had an M that would hit on every other power cycle. If I adjusted the mixture it would run either lean or rich but not smooth out to hitting on every power stroke. My buddy thought that it might be a worn intake valve guide. We put a lot of oil the valve stem and it did seem to even out some. However both engines seem to hit fine on each power cycle with a slight load - so I do not think it is spark, timing or compression. While at a show I saw another guy's M doing the same thing. Any suggesstions from M operators? Maybe this is a common problem that has a well known solution.
I'd like to have them running smoothly for shows when not under load.
Regards,
Wade
Old 05-22-2005, 12:40:49 PM
BobRR BobRR is offline
Default Re: Throttle Gov. IHC M Running Poorly
Try lightly holding the ex. valve closed when running if it smooths out you have a weak valve spring.BobRR
Old 05-22-2005, 10:01:07 PM
Exclamation Re: Throttle Gov. IHC M Running Poorly
Try the springs, and also check for play in the throttle shaft and linkages. a worn throttle shaft will lead to an erratic idle, as air will leak past the shaft. There should be virtually no play vertically or horizontally in either the intake valve or the throttle shaft.
3-5 LB won't throttle down gobuggyman Antique Gas Engine Discussion 1 11-05-2007 09:12:43 PM
FBM Z 3hp throttle help. RHudson Antique Gas Engine Discussion 2 12-02-2005 09:00:09 AM
Throttle Gov. RPM Keith Smigle Antique Engine Archives 8 09-12-2003 10:34:33 PM
Running vs. non-running engines Chris Kirk Antique Engine Archives 19 12-22-2002 08:02:12 AM
L.B. throttle rod r gryba Antique Engine Archives 1 02-23-2002 11:43:42 PM
