Bending Copper Pipe
this thread has 10 replies and has been viewed 2377 times
Old 05-22-2005, 02:04:50 PM
Bill Sommers Bill Sommers is offline
Question Bending Copper Pipe
I have a Cushman Binder engine with a screen cooling tank. It has coper pipe from the engine to the screen with all kinds of elbows and 45s. I would like to bend a piece of copper pipe to a 360 aof about 12" diameter. Can any one tell me how to bend copper pipe and make it look good and not kink?
Old 05-22-2005, 03:41:31 PM
Images: 311
Default Re: Bending Copper Pipe
I thought that we had covered this before, but it was "how to straighten copper pipe." Maybe you can get some hints from that thread, otherwise a tubing bender or maybe fill the pipe with sand. It becomes even more fun when working with brass pipe.
-- Harry Engines Videos Photos
Old 05-22-2005, 03:43:44 PM
Richard H. Gambrell Richard H. Gambrell is offline
Take a v belt pulley about the size of your intended bend and lay the pipe in it to bend. Will not kink.
Richard
Old 05-22-2005, 06:44:28 PM
Heat the copper to a straw orange color and then put it into cold water until cold. You now have a soft copper to work with. It will be much easier to bend.
The V belt pulley idea is a good one.
Jim
Old 05-22-2005, 08:01:03 PM
You can put some fittings on the end of the copper, install a grease fitting on one end and a plug on the other, fill it with oil and pressure it with a grease gun, works better than sand.
Old 05-22-2005, 09:25:51 PM
Jim L. Brown Jim L. Brown is offline
Greetings! Sounds like you have gotten lots of good suggestions - but I have a more basic question: Is it just a personal preference that you want to bend and use copper pipe? Originally these engines used rubber hose to connect the water cooling system from the engine to the cooling cone and tank. It certainly is much easier to work with and more authentic. Just a thought. Jim
Old 05-23-2005, 09:16:45 AM
Email NOT Working
J.B. Thanks for the pressurized oil/grease gun trick. I will remember that one.
My guess is you would use compression or flare fittings and just cut off the extra length when you are done. I wonder how much pressure it would take to blow a fitting off like a rifle bullet? Kevin
Old 05-23-2005, 11:53:11 AM
Images: 311
I would be more concerned about pressurizing anything with air rather than a liquid. I don't think grease or oil would go far, but couple that with compressed air and you have a problem! The reason is that liquids do not expand much when released, but a volume of air is another story.
Old 05-23-2005, 01:04:01 PM
Smile Re: Bending Copper Pipe
Thanks for the replys. I tried the sand inside the pipe and bending over a v pulley. I got a kink the first time and it just broke off the second try. I want to use copper instead of hose because you can shine it up and it looks good. I think my only choice now is to heat it. I might also try to find some 3/4 copper tubeing.
Bill
Old 05-23-2005, 01:12:08 PM
Mac Leod Mac Leod is offline
I saw on tee-vee, when they make trumpets, they freeze the pipe with h2o in it, will not kink...may try that
Old 05-23-2005, 01:46:13 PM
With grease and oil you have pressre but no compression, if you pump until the fitting comes off it will just fall off.
C Channel bending in kansas ??? Greg Shipley Antique Gas Engine Discussion 11 08-01-2006 11:33:23 PM
Bending Brass Tube Junkologist Antique Engine Archives 14 11-28-2004 06:31:57 PM
Bending Copper Tubing Paul Hokanson Antique Engine Archives 10 07-11-2003 05:43:58 PM
cleaning copper pipe RUSSELL GILBERT Antique Engine Archives 6 02-11-2000 05:10:56 AM
