lauson crankshaft
this thread has 0 replies and has been viewed 851 times
Old 06-19-2005, 08:20:11 AM
Larry Harding Larry Harding is offline
Default lauson crankshaft
i have a 2 1/2 h p john lauson model d that i bought 10 or more years ago. it sat for a long time because the timing gears had rusted the teeth off due to water standing in the sump. about two years ago i ordered some new boston gears and macnined them to fit. ever since this has been one of rhe easiest cranking best running engines i have. at a show last week it got hard to crank and i couldn't get the governor to set the way i wanted. suddenly it began to knock. when i shut it down i found the crankshaft had broken into at the timing side end of the crankpin. has anyone ever seen this happen? i know i supported the crank while putting on the timing gear and it has run for over two years. where can i find a crank to fit? if worse comes to worse i suppose i could make built up crank like is done on model engines. any suggestions?
Where to get a 3 hp FBM crankshaft CODY K Antique Gas Engine Discussion 0 02-26-2008 02:13:27 AM
Crankshaft Jerry B Scale Model Engineering 10 02-12-2008 01:00:45 PM
IHC M 1 1/2 hp crankshaft Robert Johnson Antique Engine Archives 8 01-29-2004 04:35:05 PM
crankshaft gatweedie Antique Engine Archives 1 01-25-2004 08:57:48 PM
CP&J.Lauson,Christensen,Lauson-Lawton Denis Rouleau Antique Engine Archives 0 10-21-2000 09:08:36 PM
