rust and corrosion, how to remove
this thread has 7 replies and has been viewed 2365 times
Old 06-22-2005, 06:34:28 PM
Mac Leod Mac Leod is offline
Default rust and corrosion, how to remove
on the waukesha, the valves are stuck good. the valves are rusty and the aluminum ports are corroded. seems every rust removil chemical says do not use on aluminum...I can not put this part in an electrolisis tank...any ideas?
Old 06-22-2005, 07:23:33 PM
Orrin Orrin is offline
Default Re: rust and corrosion, how to remove
The instructions on my jug of Evapo-Rust says it will not harm un-rusted steel and it is safe on other metals.
As far as corroded aluminum is concerned, the stuff swells up and things like pistons get really stuck. I've heard of people just giving in to the facts of life and breaking corroded aluminum pistons to remove them.
Hang in there.
Orrin
Old 06-23-2005, 09:37:09 AM
Elden DuRand's Avatar
Images: 6
Hang in there.
Orrin
Orrin:
I can identify with removing corroded pistons. A couple of years ago, Frank and I decided to get a Clark Airport Tug running and auction it off for charity. This little puller had a 90 HP Chrysler 6-banger flathead in it and, after sitting indoors for a long time, it had stuck. I figured that all it needed was a gentle nudge to get it turning.
I soaked it good with diesel fuel then we towed it to try to break it loose. Nothing! It wouldn't budge.
To make a long story short, I pulled the head and pan. The cylinders were near perfect so the engine had very few hours on it. Everything was free except the pistons.
I spent the better part of a week sweating to get the pistons out in one piece but the last one broke and a couple of others were pretty scored so we ended up getting new pistons, pins and rings. It would have been a LOT easier to just take an air chisel to them.
BTW, after freeing-up a couple of stuck valves, lightly honing and putting it back together, it ran like a champ.
Take care - Elden
Old 06-23-2005, 10:28:41 AM
Stationary
Gooday,
I was able to remove 1924 Buick Master hub caps (aluminium) by soaking them with citric acid. This is a mild acid and eats away the aluminium oxides,
(I think!!).
Stationary
Old 06-23-2005, 10:31:25 AM
it is the valves I am having a hard time with...the pistons I think I can take care of, once the valves are free again...Where can I get a "jug of Evapo-Rust"...If I cant get the pistons to move, and breaking them is the only option, no great loss, they are shot anyways...I think the valves can be used again...the tops are pited but the seats look good. any other ideas for rust and corrosion removal?
Old 06-23-2005, 11:38:48 AM
Robt.'s Avatar
Robt. Robt. is offline
Default rust and corrosion, how to remove: vinegar
The acetic acid in vinegar will convert rust to some sort of black powder, works like a charm. I degrease small parts, soak in vinegar for a few days and then put into an ultrasonic cleaner. The rust just blows off in the cleaner and the parts come out 'in the white', with even the pits cleaned out. Not sure how compatible the acetic acid is with aluminum, but try it. For larger items you could pressure wash them afterwards instead. Cleans up brass & copper well too. If you put the vinegar in the ultrasonic it speeds up the process of course. Complex parts where penetration is a problem could be put into a sealed container and a little air pressure applied through a tire valve or similar to force the vinegar in everywhere.
Old 06-23-2005, 09:40:36 PM
Just do a "www.google.com" on Evapo-Rust.
http://www.google.com/search?biw=950...=Google+Search
You'll get loads of hits. Take your pick.
I got mine from a vendor at a swap meet. I believe I've also seen it advertised in magazines. GEM, perhaps?
Regards,
Orrin
Old 06-24-2005, 09:28:34 PM
one of the guys I met a while ago, used to own parts shop for old euro cars...said vinigar... before I had a chance to read the posts that said use vinigar...seeing as that is cheap and avalible...I gave it a try...seems to work- slowly but thats fine...I have all the time in the world. Thanks
Why is it Best not to remove Flywheels? DerekC Antique Gas Engine Discussion 5 03-05-2008 12:42:40 AM
Best way to remove J.B weld? JKWidener Antique Gas Engine Discussion 12 09-14-2007 10:08:27 PM
IHC M Cylinder Sleeve Corrosion – Excessive? R Lebs Antique Gas Engine Discussion 2 12-10-2006 01:38:05 PM
Remove fuel tank Paul. Jones Antique Engine Archives 1 09-19-2002 10:59:44 AM
Flywheel remove mark Antique Engine Archives 6 12-31-2001 09:45:53 PM
