Thermo-Syphon Question FM 15 HP
this thread has 4 replies and has been viewed 1616 times
Old 07-02-2005, 08:48:56 AM
country country is offline
Default Thermo-Syphon Question FM 15 HP
I have a 15 hp Z and am trying to hook up a water tank for coolong
Is there any limit to how high the tank/water levels should or need to be to make sure the water circulates? I do NOT have a water pump in line.
any insight into this would be appreciated
thanks
Dave
Old 07-02-2005, 09:00:10 AM
Images: 311
Default Re: Thermo-Syphon Question FM 15 HP
http://www.smokstak.com/forum/showthread.php?t=8737
Old 07-02-2005, 09:09:23 AM
Photo Re: Thermo-Syphon Question FM 15 HP
here are some pics
Old 07-02-2005, 05:17:31 PM
Exclamation Re: Thermo-Syphon Question FM 15 HP
The tank outlet piping (cool water)to the engine from the tank should start 3" above the tank bottom, to prevent any debris in the tank from blocking this pipework. The outlet piping to the bottom of the engine cylender should ramp up toward the bottom of the engine cylender , to promote flow. The piping from the engine cylender, (hot water) should rise at least 6" vertically off the top of the cylender, and then ramp upward to the tank, again to promote flow. The water level in the tank should be at least 6" over the top of the inlet piping connection at the tank, coming from the top of the engine. This will allow the hottest water to get the most cooling effect from the air, and allow the thermosyphon to work properly.
Last edited by Andrew Mackey; 07-02-2005 at 05:20:10 PM. Reason: had to delete diagram, cannot post properly
Old 07-04-2005, 09:09:59 AM
Thanks for the insight
I am hoping to have this engine together for a show in september
Dave
my web page www.easternsurplus.net
Gauges & "syphon" on eBay David eBayŠ Auction Discussion 2 09-20-2006 05:02:28 PM
syphon 60case Steam Stationary Engines, Traction Engines, Steam Boats 9 08-03-2005 08:55:01 AM
valve guide clearance question & steam engine question Sky Antique Gas Engine Discussion 3 06-07-2005 10:50:17 PM
Thermo King Richard Clarke Generators & Motors General Discussion 0 07-22-2001 09:33:25 PM
Re: thermo-syphon Bill Hazzard Antique Engine Archives 2 08-02-1999 06:29:30 AM
