f m z 3 hp mixer
this thread has 4 replies and has been viewed 1169 times
Old 07-04-2005, 11:07:22 PM
Brickman Brickman is offline
Default f m z 3 hp mixer
when i take the mixer off there is a small brass tube , dose anyone know how long it is suppose to be ? the only way it half way runs is if i choke part of the hole on bottom of mixer, the needle valve dose not make any differnce if it is 1/2 turn out or all the way out.i have cleaned the mixer ,and blow out with air , several times . any ideas . thanks ron brown in central il.
Old 07-05-2005, 07:08:08 AM
DanR
Default Re: f m z 3 hp mixer
Ron, The brass tube can be flush with the casting or stick in a little way. It's not critical. Sounds like you have a check ball on the end of the pick up tube that's not working. Also make sure the check ball under the pump is seated properly. Hope this helps. DanR
Old 07-11-2005, 10:45:49 PM
thanks dan i donot have a cheack ball on the pickup line , i thought with the fuel pump on carb that it did not need one, it did not have one on it when i got it , but i will put one on it. and look for ball undet fuel pump .
thanks ron brown in central ill
Old 07-11-2005, 11:57:59 PM
Rudy Rudy is offline
Card Sponsor
Hi, Brickman. Just to clarify things there is no checkvalve on the end of the suction line. there is a checkball inside the brass fuelpump plunger and one underneath it. thats it. also the brass tube comming out of the mixer is 3/4 inch long. it is suppost to stick into the cylinder head close to the butterfly valve. if you need a picture to explain this or parts for this mixer look on the Hit and Miss web site in the engine parts catalog under 3 and 6 HP FM Z ignitor engines.i bought all my parts from Ed and the engine runs real well.
Old 07-14-2005, 09:27:30 PM
thanks rudy i have a show to go to this weekend i dont know if i will get time to work on it or not, i will keep you posted . thanks ron brown in central il
"Chicago Mixer" cement mixer - Help! jpasture Antique Gas Engine Discussion 2 07-23-2007 05:04:12 PM
6 hp m ,mixer Brickman Antique Gas Engine Discussion 9 01-05-2005 08:11:32 PM
Mixer Jessee Zilafro Antique Engine Archives 1 11-15-2002 05:17:32 PM
associated mixer Bill Miller Antique Engine Archives 5 11-05-2001 10:33:51 PM
Need help with LA mixer Norm Antique Engine Archives 1 08-10-2001 08:03:17 PM
