cushman C Intake
this thread has 3 replies and has been viewed 1270 times
Old 07-25-2005, 07:36:32 PM
Lindy Lindy is offline
Default cushman C Intake
Hi,I'm starting restore a cushman C #42073.While sandblasting the intake manifold I found a hole in the engine side of the manifold.After cleaning the hole this appears to be a cavity around the intake pipe.Does anyone know if this hole should have a plug or remain open?
Thanks,Lindy
Old 07-26-2005, 09:39:23 PM
John Willis John Willis is offline
Default Re: cushman C Intake
Not an expert here but there should be a matching hole in the cylinder. There needs to be a gasket where the two mate up. There should be a small slotted plug in the manifold that could be loosened or removed in cold weather. This would allow some exhaust gas to come out the small hole into the chamber surrounding the manifold to aid in vaporizing the fuel. At least that's what my little pea brain remembers.
Old 07-27-2005, 05:33:40 PM
Thanks,there is a matching hole in the cylinder.It was pluged also.Thanks again for the response.
Old 07-27-2005, 10:19:00 PM
Lon Carlisle's Avatar
Lon Carlisle Lon Carlisle is offline
I have a cushman cub and it has a slotted screw in the hole I believe you're refering to. I never removed it as my engine runs like silk so I didn't want to do anything to change it's operation. A note on your restoration, be sure to have a good fuel check valve or it'll give you fits keeping it running and make sure the fuel tank is clean, this engine does not like any dirt in the fuel system.
Intake Tube for an Engine Gary Pflum Antique Gas Engine Discussion 1 10-04-2007 01:43:08 PM
Cushman binder intake valve seal Robert Johnson Antique Engine Archives 1 03-03-2004 08:24:25 PM
Noisy Intake Valve. Bill Blackburn Antique Engine Archives 6 08-06-2003 11:42:41 PM
intake valve question Tom Winland Antique Engine Archives 4 09-02-2002 09:29:18 PM
Copper gaskets for Cushman intake valves Allan Molho Antique Engine Archives 4 09-26-2001 01:06:20 PM
