Sattley (Montgomery Ward) 1 1/2 HP
this thread has 3 replies and has been viewed 3390 times
Old 08-08-2005, 07:56:41 PM
mbrule mbrule is offline
Default Sattley (Montgomery Ward) 1 1/2 HP
Hi again everyone, attached are a few pactures of my recently acquired Sattley 1 1/2 HP. It turns over and the Wico Mag sparks great, I have to get a spark plug and oiler, based on advice here on the forum, I know what to get for an oiler. I just won a manual on Ebay that I hope will tell me about the plug.
Old 08-08-2005, 08:28:46 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
Default Re: Sattley (Montgomery Ward) 1 1/2 HP
Just about any old hit and miss engine will run off of a Champion #25 plug. Still readily available at your local autoparts store and it may be helpful to mention that it's a marine plug now. 1/2" Pipe thread and they'll think the thing is humongous. Good luck on getting it running again!
Old 08-08-2005, 09:44:02 PM
Elden DuRand's Avatar
Images: 6
There are only two types of plugs I've ever seen in a flywheel engine.
One is a common 1/2 inch pipe thread plug. Just ask for a plug for a Model T Ford from 1908 to 1927.
The other type is a 7/8", again used on Model A Fords from 1928 to 1931.
Both of these types were used for many makes of cars, tractors, trucks and stationary engines.
In other words, if the plug's good and will screw into the head, it'll work.
Good luck and take care - Elden
Old 08-09-2005, 08:58:11 PM
Harold Bobo Harold Bobo is offline
I have the same engine, My best runner. Takes 1/2" plug, I use champion 25. Needle valve touchy on mine, I leave it set and ground the mag to shut it down. Model A valves and piston will work if needed. Timing is also touchy but once it is set it stays. Check your govenor weights for worn pins, I sheared on once while running, Fortunatly no damage done.
Harold
Help! Montgomery Ward Generator gbear Generators & Motors General Discussion 6 01-05-2012 03:17:01 PM
Montgomery Ward Hummer kelby Small Air Cooled Gasoline Engines 1 05-20-2007 10:49:08 PM
MONTGOMERY WARD 3HP John R.Catoe Antique Engine Archives 0 12-12-2002 08:56:28 PM
Sattley-Montgomery Ward Governor parts Jim Tremble Antique Engine Archives 2 01-02-2002 06:58:30 PM
Montgomery Ward Sattley, newbie rhudson Antique Engine Archives 8 11-16-2001 08:50:45 AM
