Garden Tractors / Mowers / Scooters Vintage lawn and garden tractors, mowers, snowmobiles and other old machinery that is driven by small air cooled engines.
Standard Monarch Tractor
this thread has 14 replies and has been viewed 5254 times
Old 01-02-2006, 09:37:59 PM
Wayne Taylor Wayne Taylor is offline
Smile Standard Monarch Tractor
Hi, I am new to this forum. Recently purchased an old Standard Monarch Tractor with a sickle mower. Need all kinds of info. Tractor is not running and would like to be able to restore the tractor. Thanks for your help.
Wayne
Old 01-02-2006, 10:04:39 PM
sparkplug54 sparkplug54 is offline
Default Re: Standard Monarch Tractor
What type is your Monarch? Is it a single or twin cylinder? I also have a Monarch that runs and is all complete except for the wheels. I think the Monarch is a single and the Standard Walsh or Welsh is the 2 cylinder.Dan sheldon
Old 01-02-2006, 10:13:20 PM
It's a single cylinder.
Wayne Taylor
Old 01-02-2006, 10:22:50 PM
Bill Schaller Bill Schaller is offline
Take a look.
http://www.donaldantiquerototillers....ard_text1.html
Old 01-02-2006, 10:33:55 PM
Hey thanks alot Bill, according to that web page mine is a 1940. I didn't know that. Dan Sheldon
Old 01-02-2006, 10:53:22 PM
Thanks Don. Looks like my tractor is a 1949 model. I plan to contact that site and see if they still have manuals available.
Anyone else that has any parts available, let me know. Looks like I need a mag. for sure and not sure what else yet?
Wayne
Old 01-02-2006, 11:20:13 PM
Tom G Tom G is offline
Wooden or metal handles? Steel wheels or rubber tires? Coil and battery, or magneto ignition?
Best advice I can give you is to get your hands on a manual BEFORE you start tinkering. Bill S. has provided a link for Donald Jones' website. See if he can provide you with a reprint manual.
Word of caution. There is a large plug on the bottom of the crankcase which appears to be a drain plug. This is actually the oil pump. If it is removed and tilted, small parts can fall out. Also, if you remove the sickle bar mower, be sure and have the tractor propped up. Without an attachment on it, the tractor will try to fall forward. I've seen some with broken fins on the front of the cylinder, making me suspect that they had fallen over.
The connecting rod used in these tractors appears to be a Model T Ford unit. The "FORD" logo is stamped on the rod. Some folks will tell you that the piston is also a Model T piston. This is not possible, because the Monarch piston is not the same size as the Model T piston.
I've been fooling with Monarchs for several years now, and think they are rugged, easy starting tractors.
Old 01-02-2006, 11:45:11 PM
Default Re: Standard Monarch Tractor - Yahoo Group
There is a Yahoo group for folks interested in the Standard Twin and Monarch tractors. http://groups.yahoo.com/group/StandardTwin/
Old 01-03-2006, 10:58:39 AM
Thumbs up Re: Standard Monarch Tractor
Tom,
My tractor has metal handles and rubber tires. Don't know about battery and coil or magneto as it is missing as is the starting mechanism.
I plan to contact Donald Jones to check for a manual.
Thanks for the info.
Wayne Taylor
Old 01-03-2006, 07:41:09 PM
Mine is battery ignition with steel wheels and lugs.I do have the wheels but they aren't on the machine right now.steel handles also. Had the orginal hand crank but that got stolen at a flea market where I was selling. Oh well, hope the person that stole it breaks their thumb. Dan Sheldon
Standard twin tractor Mike Schweikert Garden Tractors / Mowers / Scooters 44 11-07-2015 09:33:17 PM
Standard Engine Co. Walk behind Tractor patriot76 Magnetos, Ignition Coils and Spark Plugs 3 06-22-2014 05:02:30 PM
Monarch Tractor Sulky Tom G Antique Gas Engine Discussion 1 06-16-2006 11:48:56 PM
Standard Monarch Exhaust Valve Tom G Garden Tractors / Mowers / Scooters 5 01-02-2006 11:25:15 PM
purchase standard walk behind tractor dick from Ct Antique Farm Tractors 1 08-01-2004 02:02:05 PM
