Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Caterpillar D7 Engine
this thread has 19 replies and has been viewed 16023 times
Old 03-20-2006, 09:30:37 AM
Dustin D Ehli Dustin D Ehli is offline
Images: 15
Default Caterpillar D7 Engine
Hello all, does anyone know where or if it would be possible to find an engine for a caterpillar D7, we have 2 at home but one has the engine block split right down the middle from lack of antifreeze and a North Dakota winter. our D7's have a very large 4 cylinder diesel engine with a 2 cylinder gas starting engine on the side of the diesel. are there junkyards with this kind of stuff?
Dustin Ehli
Old 03-20-2006, 11:08:58 AM
Tanner Remillard's Avatar
Images: 10
Default Re: Caterpillar D7 Engine
You might try Jim Zimmerman out of Iowa. He is listed in GEM every month for Cat parts. Not sure if he would have what your looking for, but he probably has a good idea of where to find it. His number is 641-982-4207
Old 03-20-2006, 11:13:13 AM
Jerry Willis Jerry Willis is offline
Give me the serial# off the engine will check out here in CA. Jerry willis
Old 03-20-2006, 11:52:54 AM
Images: 15
thanks guys, i won't be able to get serial numbers or anything unitl this weekend when i go home because thats where the thing is and i am a broke college student so i probably wont purchase anyting very soon but i just wanted to know if they are out there for the future.
things like the D7 should not be that rare.
Thanks, Dustin
Old 03-20-2006, 12:49:48 PM
Ken Majeski's Avatar
Images: 45
There are a few different versions of the D 7 and Engine. The 7 M, the 3 T, and the 17 A, ( most 17 A's are Turbo) come to mind. They are out there as the D 8800 ? power unit used the same engine. A guy near here has about 3 or 4 of them sitting behind his shed... Some Good and some maybe not so good...??? Yup, some could be for sale...????
Ken Majeski, Ellsworth Wis.
Old 03-21-2006, 05:36:04 AM
Kiwi Todd Kiwi Todd is offline
Photo Re: Caterpillar D7 Engine
Sorry no D7 available, but I went and retrieved this old RD7 Cat engine for a friend yesterday....Quite a job as it turned out. I think the engine alone was around 2 tons +....this one is about 1935 I think?.
Kiwi Todd
Old 03-21-2006, 09:02:00 AM
Images: 15
Kiwi that looks like the same engine that is in our d7's
Dustin
Old 03-21-2006, 12:17:40 PM
Images: 45
If you look below the seat on the Left rear corner of the main Chassis you should see the serial number stamped there. It should start with 7M, 3T, or 17 A and that should tell you what type of engine you need. Actually the 3T that I had had an older 7 M engine so you can interchange them to a point. The 7M and 3 T had a dry clutch where the 17 A was a wet clutch.
Old 03-21-2006, 09:50:48 PM
Eric Best's Avatar
Eric Best Eric Best is offline
I thought the earliest D7s could have the 9G code just like the RD-7. Maybe I'm remembering wrong.
Old 03-21-2006, 11:04:02 PM
Images: 45
Well they made D 7's way before the one that I had so you could be right. I think the one I had was sometime in the early 50's... I know it had the earlier 7M engine as I know the guy that changed it.
Only piece of Cat Equipment I have now is a 212 Grader.... That has the same engine as a D 2... Just a Little Squirt...
Caterpillar D318 Marine Engine sparkysparks32 Generators & Electric Motors General Discussion 18 06-12-2011 04:55:58 AM
Caterpillar 6point9diesel Dozers and Crawlers 17 11-01-2010 01:25:05 PM
Holt Caterpillar engine CaptainJohn Scale Model Engineering 133 02-05-2009 07:30:37 AM
Caterpillar 50 smtwins Dozers and Crawlers 8 11-25-2007 08:11:25 PM
Caterpillar help Ivan Antique Engine Archives 3 03-11-2004 11:52:14 AM
