Old Buda Engine designations (IU,ITU,etc)
this thread has 14 replies and has been viewed 5806 times
Old 03-19-2007, 06:14:52 PM
Default Old Buda Engine designations (IU,ITU,etc)
In going thru old catalogs I note a number of Buda engines with an additional "T"added:
CU, CTU
IU, ITU
XU, XTU and so on.
Some trucks use the plain version, some the "T" version, and some show with both.
Without having to laboriously sort thru listings, does anyone know, off the top of their head, what the additional "T" designated?? Any comments appreciated.
Old 03-19-2007, 10:10:22 PM
Glenn Gieszler Glenn Gieszler is offline
Default Re: Old Buda Engine designations (IU,ITU,etc)
Bud
I will give this a wag: according to my book
First digit is the series of engine IE A,B,C,D and so on
second digit is application B=bus T= tractor or truck
third digit is always U must have something to do with the name BUDA maybe his second wifes name the one that got most of the company stock in the divorce (Uranus) it might not be spelled correctly but I bet he might have felt poorly in the end or wondered of she came from the same planet (really guessing on this one)
forth digit is I for Industrial locomotives
now I was doing allright with this theory until I came across YR or YRA
R= runs or they gave you the runaround to find parts? or another thought risk assessment
Old 03-21-2007, 01:01:01 AM
JoeB JoeB is offline
While digging for some Buda detail I came across and old Buda ad that gives a nice dimensional breakout of bore & strokes for some of the tractor models. -Joe B
Old 04-03-2008, 07:14:01 PM
G Willikers G Willikers is online now
Would anyone know the difference between the model "TU" and model "HTU" Budas? These were both 4 cylinder tractor (and truck) engines, circa late teens/early 20s. Bore and stroke appears to be 4.25 x 5.5 for both.
I am wondering if the HTU means a different clutch housing, perhaps with provision for electric start? Any ideas?
Thanks for any help,
RM
Old 04-03-2008, 09:37:00 PM
DesertExplorer DesertExplorer is offline
Second digit is application B=bus T= tractor or truck
Third digit is the type of clutch/flywheel housing or type of oil pan etc... "U" means the engine's clutch/flywheel is enclosed.
The Following User Says Thank You to DesertExplorer For This Post:
Old 04-18-2008, 08:15:39 PM
Paul Johnson Paul Johnson is offline
Question Re: Old Buda Engine designations (IU,ITU,etc)
We at "Sukanen Museum" have a M-H #3 with a Buda HTU .
But the block is trash. Anyone willing to part with one ?
We want to restore this tractor. For the engineers, how many prefer threshing with a straight belt?
Old 04-21-2008, 05:15:27 PM
Malcolm Robinson Malcolm Robinson is offline
Hello Paul,
Is your Massey Harris a #2 with the Buda? my #2 has the Buda and my #3 has the Wisconsin engine.
What is your serial number? can you post us a photo of the tractor?
I also know of a #2 being restored in Belgium which requires a Buda motor block.
Malcolm.
Old 04-21-2008, 06:56:02 PM
When the weather warms up a bit more , will get a photo and post it.
The tags were sold by mistake to someone in Ontario, so no data, of course no names so it will be hard to buy them back;
maybe we will get lucky and he will see this site and contact me.
Old 04-23-2008, 11:11:27 AM
Originally Posted by Malcolm Robinson View Post
Hello Paul,
Malcolm.
Many thanks G Willikers for spotting my crazy mistake, the MH#3 is definately a Waukesha engine and not Wisconsin, somehow got my "W" mixed up here late at night during a senile moment.
Sorry for any confusion.
Malcolm.
The Following User Says Thank You to Malcolm Robinson For This Post:
Old 04-23-2008, 12:37:51 PM
G Willikers: Can you fill me in on the Wauk in the MH#3...that model falls into a hole in my stuff...
In a 30 catalog I have #2, a 12/22, with the HTU, and a 10-20 with no model number shown, using a Case motor (no Case ID or b/s shown) apparently made for MH...everything else I have (which is not much) jumps up into bigger numbers.
Just the tractor rating and the Wauk ID is all I need for my notes. Many thxx!! Bud
Buda gas V8 truck engine ? Gary Roth Antique Autos and Trucks 0 08-12-2007 02:54:38 PM
buda engine kyle blankenship Antique Engine Archives 2 10-25-2004 08:21:02 PM
Buda engine? Chris Kirk Antique Engine Archives 6 05-15-2004 02:55:19 PM
Buda engine John Ostini Antique Engine Archives 0 05-23-2003 11:50:42 PM
