Restoration Project Stover 2HP KA
this thread has 26 replies and has been viewed 9625 times
Old 12-05-2007, 07:17:43 PM
Path Path is offline
Default Restoration Project Stover 2HP KA
Hi
I joined this forum back in October 07 because I have been interested in Hit & Miss Engines for a couple of years now. I spread the word around that I wanted a small engine to restore. Well I got a call that one was available in Santa Barbara (about 30 miles north). Called the seller .... already sold ... party to pick it next week. Darn!! A few weeks go by another call ... the deal fell through so we drove up there and picked it up a few days later.
The picture shows what I have and what came with it .... not sure that all the extra items belong to this Stover ... time will tell.
This Stover (KA195078) was built in 1928 according to a serial number/date built list which agrees with the date that is on the block ... February 1928.
I really wanted a Hit & Miss, but since picking it up I have learned that it might not be a Hit & Miss, that it could be a Throttling Governing type, but that's okay I will still get it running!
I contacted Hit and Miss Enterprises and spoke with Anthony, he suggested that I start out with the KA manual/parts list and a booklet by F.B. Wright "The Small Single-Cylinder Gas Engine" to get me started. Since then I searched this forum on the Stover engine ... lots of good information.
So here what I will be doing ...
Take pictures, remove parts, take pictures, log the parts, asking questions, asking more questions, sandblast them, prime and paint. Either buy new parts or machine new ones depending on cost, complexity and availability.
I'm hoping that forum members will jump in and help me stay out of trouble!
So ... off I go to remove the Flywheels that certainly will reduce some weight!
I will be posting my progress here (short version) and on my web page http://phutcheson.net under Projects ... Stover Restoration. (It will be a few days before I can update the site with the Stover page.)
Any thoughts, advise or questions?
If anyone needs pictures or information about my KA just let me know!
Thanks,
Pat H
Name:	Stover KA 2HP.jpg
Old 12-05-2007, 07:59:44 PM
Ironman Ironman is offline
Default Re: Restoration Project Stover 2HP KA
For starters, your engine appears to have a detent arm on it which would confirm that it is a hit and miss engine. Stover built the KA engines in both hit and miss and throttle governed versions. The throttle governed engines did not use a detent lever.
The square shaped magneto with the brass outer cover is the correct style of magneto for your engine. It is a Wico EK magneto. The one pictured is obviously far from being complete. There are plenty of EK magnetos out there so locating one should be very easy.
The magneto that has the horseshoe shaped magnets on it is a Webster magneto, and is a "bonus" item because you can sell it and put the money you get for it towards buying a complete Wico magneto.
Take a picture from the head end of the engine and post it here. It is hard to tell, but I believe that the engine is missing the carburetor (mixer). The one pictured in the group of parts appears to be a Briggs & Stratton or other small engine carb.
Looks like the exhaust lever and bracket might be correct.
Other than the aforementioned items, I believe the rest of what you will need will be minor items like springs, gaskets, etc. Reproduction crankguards are available, as well as reproduction mufflers. Reproduction springs are also available, as well as head gaskets and carb gaskets.
Try contacting Starbolt Engine Supplies (you can email them through their link on the SPONSORS page on this website) in regard to any parts that you might need. I believe they should have anything you need except for a carb.
If you need part numbers for anything before you get a parts book let me know. I have an original parts book in my filing cabinet. Also, I believe that I might even have a correct carb.
Lastly, it's purely your choice, but I would not personally recommend sandblasting the engine parts. Sand gets in the porous parts of the castings and can find its way out later and could cause wear. With an engine that small, you should easily be able to clean it up nicely by using a wire cup brush in an angle grinder, using a wire wheel on a bench grinder, and small wire wheels that you can chuck in a drill. I've restored MANY engines by using wire brushes and wire wheels to clean the parts.
Old 12-05-2007, 08:24:33 PM
Ray Cardoza's Avatar
The carby is off of a briggs but im not sure what series.
Old 12-05-2007, 09:02:05 PM
Ironman,
Thanks for the information.
Attached is close up of the Head (it is a thumbnail)... I don't see any type of mixer either.
Glad hear the it should be a H&M!
I want to discuss the rust removal process more in detail, but must get ready for a CNC class.
Ray ... yes that carb was just thrown in at the last minute !!
So I will continue this tomorrow.
Pat H.
By the way ... I'm able to post the pictures as thumbnails but how do get the outline and notation like the other threads?
Old 12-05-2007, 09:27:20 PM
Nathan K. Nathan K. is offline
HI Pat,
Looking at your photos I don't think the carb., fuel tank, or the magneto with loop magnets(end plate missing,it may be sitting by the other mag), are for your engine. It looks like your engine had a Wico EK magneto the remains(box with wires coming out) looks like they made it in to a coil box Parts are still available for them. I think there is a fuel mixer on ebay that may fit your
engine. Hope this helps. Nathan.
Old 12-07-2007, 05:34:52 AM
Nathen,
The only carb/mixer on ebay that I have found so far is for the CT1 ...don't know if that one will fit or not. The one I'm looking for I believe will be marked with a 125K2 for the H&M; according to Stover Manual / Parts List L62 (from Hit & Miss Enterprises). What .... you don't like my BLUE fuel tank?
Ironman ...
You mentioned that you may have the correct carb for my KA. Can you provide details and maybe a close up picture? Email me costs.
Now about sandblasting ...
What I had in mind was sandblasting (sand or other abrasives) the surfaces that did not touch, for example .... the flywheels, parts of the head, frame etc.
But not any linkage, cylinder walls, piston etc. Of course those areas would have to be well masked off ... I hear the blasting gets material everywhere. And finally picking out the correct abrasives, all this is to be determined.
Maybe another concern would be that the sand would prevent a good paint job if it stayed in the porous of the casting.
Ken Stuempges reconditioned a Stover KA back in 2003 see his web site at http://www.thehermitsmachineshop.com/Index.html
So I'm not sure yet ... I really want this to be a good lasting restoration and do not want problems later on ... so blasting may not be the way to go. Your method sounds like it will be (and has been) very good. So the work done would be worth that extra effort.
Looks like the Wico EK may be the biggest issue I have ... so I will start looking into what it will take to either rebuild the near empty box I have or buy a reconditioned one.
Hope to have my page up this weekend .. with lots of pictures.
Thanks again,
Pat H
Old 12-07-2007, 11:18:33 AM
FarmallIH
Congrats on the Stover I just got a KA running for the club I bleong too, was in better shape then yours. The one I got running was a throttler had linkage that goes up to the mixer. They are a nice running engine.
Old 12-07-2007, 05:56:01 PM
Randy Gauny Randy Gauny is offline
this is on a THe Kid pumping unit maybe some helpClick image for larger version
Old 12-07-2007, 10:43:47 PM
HI,
I found the mixer that I was thinking of, I looked and it's for a throttle gov. engine so no good. Nothing wrong with the tank, just tank/engine combo?.
If it was my engine I would just clean it and spray some diesel on it, It makes a great historic looking engine that you can belt up without living in fear of a scratch. Nathan.
Old 12-10-2007, 03:07:12 PM
Okay ... my web site page for the restoration project is now on line http://phutcheson.net click Projects then Restoration ... Stover Hit and Miss Engine. There are lots of detailed pictures ... as the project moves along I will update with new information and of course pictures.
If you have any questions, comments or helpful information please post them here or email me direct.
Nathen ... no way will that very ugly gas tank will ever be mounted my Stover!!
Thanks for looking for the mixer. Did it have a part number on it? I think I'm looking for one that has part number 125K2 (the new Symbol #) or 7005K (Old #).
Can anybody confirm these numbers?
I think for my 1st HM I will paint it, let the new owner in 100 years or so keep it ancient looking.
FarmallIH Great You Tube clip ... thanks.
Randy ... Thanks for the picture ... it all helps.
Here's my next step ... search the forum for Primer information, paint will come later. As I remove the rust I need to protect the surface as soon as possible. No use letting rust come back!
Also I will looking for the mixer and WECO EK (either a rebuilt unit or the parts).
This should keep be busy for the next week or so ...
Thanks,
Pat H
First Briggs&Stratton Restoration Project Updates Hit and Miss kid Small Air Cooled Gasoline Engines 7 02-13-2008 05:50:23 PM
Stover CT2 (My first restoration) guyver11469 Antique Gas Engine Discussion 8 09-27-2007 08:37:25 PM
Onan DJE Restoration Project Jonathan Onan Generators 69 01-15-2007 12:08:41 AM
DJE Restoration Project Jonathan Onan Generators 14 10-26-2005 04:18:48 PM
Stover Engine Restoration David+Baughman Antique Engine Archives 3 11-17-2003 01:29:42 PM
