15.0 jc fuel consumption
this thread has 1 replies and has been viewed 6913 times
Old 02-10-2008, 11:51:52 PM
Stephen Girouard Stephen Girouard is offline
Default 15.0 jc fuel consumption
i recently put a new gasoline carb on my jc and had to open the main jet a little more before it ran well under load, anyone knows the fuel consumption spec's for this unit on gasoline. i'll be testin it underload naturally so if you have a spec that specifies under how much load i would apreciate it, i may also run it on propane one day i have the gas carb and a 100 gal tank my second question wold be whats a good regulator/ vaporizer to use ? thanks for ya'll help folks
Old 02-11-2008, 10:22:10 AM
Jack Hottel Jack Hottel is offline
Default Re: 15.0 jc fuel consumption
Stephen,
For a 15.0JC at 60Hz, (1800 RPM), the gasoline consumption in gallons per hour is:
Load: 0 1/4 2/4 3/4 4/4
GPH: 1.0 1.3 1.6 2.0 2.4
Good Luck
Jack Hottel
12.5 Fuel Consumption Delta13 Onan Generators 1 08-27-2006 03:48:29 PM
Fuel consumption Simple_serf Onan Generators 3 01-25-2006 01:46:32 AM
45.0 EM Fuel Consumption Jim Davis Onan Generators 0 01-23-2006 09:41:26 PM
LP fuel consumption for 10CW-3R/1A Dwight Mossman Onan Generators 12 11-02-2005 08:14:30 AM
20 HP-N Fuel consumption Alan James Antique Engine Archives 2 04-12-2004 05:28:59 PM
