Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Caterpillar Sixty running with a vacuum leak video
this thread has 2 replies and has been viewed 2916 times
Old 09-22-2008, 03:26:59 AM
Eric M. Eric M. is offline
Default Caterpillar Sixty running with a vacuum leak video
The shrimp in the plain black shirt is me. I think we have a slight leak houston
This is the first time in 5 years this 60 has run. Apparently another crack opened up in the manifold. No wonder it wouldn't start by hand
The cylinders are heavily oversized. They were an aftermarket set built 1/4" over, then bored 0.080" on top of that. Add a set of 3/4" pop-up domed pistons and a twin-stack setup and we have music!
The Following 4 Users Say Thank You to Eric M. For This Post:
Old 09-22-2008, 10:39:35 AM
Default Re: Caterpillar Sixty running with a vacuum leak video
On the upside, Eric, it isn't belching black smoke.......
SHRIMP?....... .......I didn't see any shrimp.......
Old 09-22-2008, 08:50:44 PM
Nope, we never got it to smoke at all. The stacks were totally clean. Even while cranking it with gas slobbering out the intake and several HEALTHY doses down the priming cups. I think the 1/16" by 5" crack helped lean the mixture out somewhat.
3hp HVID running video tim l kesler Antique Gas Engine Discussion 2 08-30-2008 10:40:42 PM
Video of the Kinkade running. JKWidener Small Air Cooled Gasoline Engines 4 06-04-2008 05:18:59 PM
Video of Single Ruston Hornsby Running Mike Inglis Antique Gas Engine Discussion 3 12-23-2007 11:03:25 PM
Briggs OHV 14hp, oil leak, & rough running? Smith Brother Small Air Cooled Gasoline Engines 16 10-02-2006 09:05:21 AM
Gilson 7HP Goes Like Sixty Dave Martin Antique Engine Archives 4 02-23-2003 02:44:37 PM
