Fairmont Railway Engine Questions
this thread has 11 replies and has been viewed 4343 times
Old 04-25-2009, 10:46:19 PM
wsrutherford wsrutherford is offline
Default Fairmont Railway Engine Questions
I have a Fairmont Railway Engine, that's been in the family 25-30 years, maybe longer!. And its the ONLY Fairmont I have ever seen live & inperson.
This is what I know, it has a brass tag on the water hopper that reads, FAIRMONT QB, serial # 32419.(made about 1927-28, I think)
There is NO serial # on the pad under fuel tank.
I have a copy of Fairmonts spare parts list for the QB dated Oct 15 1931.
The parts list says a QB uses flywheel #'s QB-1 and QB-2!
The flywheels and crankshaft are tapered, the flywheel casting # is 772 on timer side and 773 on pulley side,
Does this mean it has been upgraded to a QBA??
What else is different between the QB and QBA??
I may have some part missing on timer side?
There was no side bearing spacing collar (QB-15L), between the spacing spring and the side bearing packing sleeve (QB-315)!
If this engine has been upgraded to a QBA is this part still used (QB-15L)?
Also it had a large ring that I can't find in the parts list, and it had no use where it was at, anyone got any Ideas on what it is and where it goes?
I Appreciate Time and Help!
Steve
Old 04-26-2009, 06:29:59 AM
Chuck Woycke Chuck Woycke is offline
Default Re: Fairmont Railway Engine Questions
steve,can you post a picture of your engine,i have several old fairmonts lying around the barn even have 2 of the rare one.s the twin cylinder engines.have severl manuals also,chuck
Old 04-26-2009, 08:40:06 AM
I'll post some pictures later today, this is my first post, so when I find out how to edit my post, I'll clear up some things I wasn't real clear about!
Thank You
Steve
Old 04-26-2009, 11:05:09 AM
Thanks Chuck, Here are some pixs, Let me know if you need more? The ring I wasn't real clear about was between the timeing and throttle levers and caused the timer lever to rub flywheel, and the spacing collar thats missing goes between the spring and the sleeve w/ the rings. (I think)
Thank you for your time!
Steve
ID:	53152   Click image for larger version
ID:	53153   Click image for larger version
ID:	53155   Click image for larger version
Old 04-26-2009, 02:06:25 PM
BobM BobM is offline
im no exspert i have serial 29163
witch is just QNB 1924
might not be the same but i will send you my email maybe trade pics could help
bob
Old 04-26-2009, 03:45:14 PM
Scott's Avatar
Scott Scott is offline
According to my manual one of the changes was the QBA got the tappered flywheels and crank and looks like they changed timers and possibly piston pin. Is that ring the gasket that goes inside the bearing cap Part # QN-15E?? . You should have the same spacer collar QB-15L on the other side and you can get the dimensions and have one made.
Old 04-26-2009, 11:15:40 PM
Scott, No it's a steel ring, QN-15E is a "paper" gasket, I think? Where did you get your manual? I need one!
Thank You Steve
Old 04-27-2009, 08:26:10 PM
Dirk Jr Dirk Jr is offline
You can get your manuals from Harsco. (Fairmont) Should be no problems if you have a serial number or you know the engine model.
Old 04-28-2009, 08:39:00 AM
Dirk, Thank You !
Has anyone bought any manuals from:
http://rrstuff.hawaiihost.us/libconts.htm
Steve
Old 05-03-2009, 08:36:14 PM
Phil Phil is offline
Images: 23
Steve:
Isn't it funny how those ignition parts go missing, and off of almost any engine, too. Maybe they are tasty to Martians.
I have Fairmont QB 34447, with the same disorder, even missing the belt sheave (dessert?). I've been under the impression that the QB's were not intended for railroad service, but for general stationary use. Those flywheels seem heavier (fatter) than what I've seen in speeders.
Would love to get the QB popping, but haven't mustered the courage yet.
Hope you get 32419 up and running!
Best -
Phil
Fairmont timer questions Zira Antique Gas Engine Discussion 6 01-09-2009 08:52:47 PM
Fairmont/Woolery engine questions Mel Miller Antique Gas Engine Discussion 4 11-01-2008 12:41:26 PM
Fairmont Model D Questions jrodarte1 Antique Gas Engine Discussion 5 02-23-2007 11:02:48 PM
railway engine, not a Fairmont Marty Antique Engine Archives 14 06-26-2003 03:34:41 PM
FAIRMONT RAILWAY ENGINE DENNIS WILKENING Antique Engine Archives 3 02-16-2000 10:05:17 PM
