Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Another strange crawler
this thread has 14 replies and has been viewed 5089 times
Old 02-24-2010, 02:57:53 AM
cletracker cletracker is offline
Default Another strange crawler
Found this photo of a strange crawler in forest duty, Speed Cat. Photo was taken in the States. Does anyone have any information about this strange crawler? Photo taken in 1932 according to archive notes.
The Following 6 Users Say Thank You to cletracker For This Post:
Old 02-24-2010, 11:09:23 PM
Rene Elliott Rene Elliott is offline
Default Re: Another strange crawler
I've heard the name before but never seen anything like it. It almost looks like dump body hinge castings on the back?
The Following User Says Thank You to Rene Elliott For This Post:
Old 02-25-2010, 02:11:05 AM
if you guys like crawlers their is a group on here that i started i would like to see that picture posted in the photo section thanks agian for sharing.John
Old 02-25-2010, 11:27:18 AM
6point9diesel 6point9diesel is offline
It looks like the track pads are attached to 3 cables. Kind of a stepping stone to the steel belted rubber tracks of today. It's a neat design and sharp looking crawler. I'd be curious to see one operational.
Thanks for posting!
Paul
Old 02-25-2010, 03:50:23 PM
My observation would be that the whole track pivots at center, it is built for light weight design, it appears to have no raised creeper teeth, for less tearing up the ground or roadways, but would make me question traction. Linn advocated two driving sprocket teeth to keep the track running "true" vs. his Lombard experience with single drive teeth in the middle. Also, Linn wanted to keep his drive sprockets up off the ground, for less wear or chance of getting anything stuck in there. I didn't pick up on the cable-looking belt system, again indicating intentional lightweight design, not heavy duty pulling or load carrying. I guess that's why thy called it a "Speed Cat"? Metal tracked machines of that age were pushing it at a sustained 8 mph, maybe this one could do 15 mph or better?
Old 02-25-2010, 04:35:52 PM
In the 60's there was a small crawler called a Mead Speedcat,although nothing like the pic. But, I wonder if Mead Morrison had anything to do with making the one in question. Mead Specialties co. built the newer speedcat. Were they in some way connected with the old Mead-Morrison co.? Perhaps the newer company bought the speedcat name from the old one and built there own machine years after? Mead-Morrison was involved in lots of different equipment,perhaps they even tryed the light duty crawlers too.
The Following User Says Thank You to David Hoover For This Post:
Old 02-25-2010, 10:55:34 PM
Thanks! Forgot Mead Morrison made Speed Cat, then this machine would probably be a winch platform, and would explain using a cable in the track? Linn used Mead Morrison winches is about all I know about them, mounted under the cab seat (Std. Oil of CA Linn at West Kern Oil Museum in Taft, CA set up this way), or right behind the cab for using a boom or just to load themselves.
Old 02-26-2010, 03:17:29 AM
They built crawlers back in the 20's, and those early crawlers had the same basic track design,with just the 3 bottom idlers. They built just about anything to do with hoisting, winches,shovels , lots of atachments. I'd say they would be a good candidate to try making tracks out of cables too.
Old 02-26-2010, 06:31:05 AM
Jerry Sweet Jerry Sweet is offline
When I worked around Kenai,Alaska during the 1950s & 60s,survey,utility & Geophysical people used a thing that looked about like that,except they had heated,inclosed cabs.They had very wide pads with no grousers.They could travel about 30 M.P.H. They were called "Weasels". Instead of track rollers,they had two or three rubber tired truck wheels on each side that took the place of upper and lower rollers.
The Following User Says Thank You to Jerry Sweet For This Post:
Old 02-26-2010, 10:36:51 AM
Very interesting. Looks like we may have some kind of Mead Morrison crawler winch platform. The driver seat sits on the engineside, for better control when winching? Can anyone see the winch? The two big fixtures on the back are interesting to, is this for the earthanchor when winching? If it´s not a machine for winching could it have been used for dragging timber? Track does not look that strong but very flexible=fast and that´s against the dragging theory. Hmm... I´m confused, what is it?
Strange oiler J Eddy Antique Gas Engine Discussion 3 01-10-2010 10:01:24 PM
Strange Pump T.Babbie Antique Gas Engine Discussion 3 12-16-2009 06:54:27 PM
Got a strange engine could someone tell me more about it? IronCity2006 Antique Gas Engine Discussion 10 04-29-2008 02:49:04 PM
Strange little engine Jim McCracken Vintage Diesel and Oil Engines 10 03-16-2007 12:12:25 PM
