Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Caterpillar D2 Fuel Pressure
this thread has 5 replies and has been viewed 3956 times
Old 05-03-2011, 06:37:57 AM
Mtype Mtype is offline
Default Caterpillar D2 Fuel Pressure
hi guys i am working on a d2 3j i have had it for a wile and have done alot of work around my farm with it. the problum i have with it is when it idling the fuel pressure is hunting really bad witch is making the engine hunt i can't remember what the pressuer differance is but its a fare bit. so i am asking all you guys for advice on what i should be looking for so i can fix the problum. thanks cam
Old 05-03-2011, 07:01:28 AM
Dick Brown Dick Brown is offline
Default Re: d2 cat fuel pressure
Check the fuel supply pump there is a check valve in it that could have trash under it. the valve and spring could need replaced. if the pump seals are bad they usually will leak fuel at the weep line on the fuel filter housing.
if you have a parts book it will show detailed pic. of all this..
Hope this will help.
Dick Brown
Old 05-03-2011, 07:07:14 AM
mschreiber mschreiber is offline
easy 1st, filters.
Old 05-05-2011, 05:49:04 AM
Default Re: Cat D2 Fuel Pressure
thanks for the info i will pull the pump off on the weekend and have a look at it. thanks cam
Old 05-22-2011, 03:56:52 PM
charles culverwell charles culverwell is offline
Default Re: Caterpillar D2 Fuel Pressure
i have one if there the right numbers my e-mail is elizabeth89008@yahoo.com thanks
Old 09-28-2012, 02:56:01 AM
ebeday ebeday is offline
I'm thinking the fuel "hunting" problem is caused by the engine hunting, not the other way around. I need to see which governor the 3J engine had, I will write again.
Help me please looking for a Caterpillar D2 3J fuel pump Mtype Dozers and Crawlers 5 03-22-2013 04:40:19 PM
Electric Low Pressure Fuel Pump? BTPost Onan Generators 4 04-24-2011 10:55:13 PM
Wisconsin V-4 fuel pressure farmer24 Wisconsin Engines 4 01-19-2010 06:35:02 PM
Too much or too little fuel pressure flasks Antique Gas Engine Discussion 16 01-25-2009 01:23:40 PM
Low Pressure Fuel Pump JNorton Onan Generators 2 07-19-2007 08:40:53 AM
