Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
Caterpillar 22 oil change
this thread has 4 replies and has been viewed 2754 times
Old 05-28-2011, 11:54:09 AM
Nevr-Enuf-Stuf's Avatar
Nevr-Enuf-Stuf Nevr-Enuf-Stuf is offline
Default Caterpillar 22 oil change
The original manual states using s.a.e. 30 oil, Im assuming non-detergent would be the best on an original (non-rebuilt) engine. But the manual doesnt state how many qts.?? Also was there ever a shop manual for these crawlers, like a Motors of Chiltons would be, something with more detail and breakdown of all the components, troubleshooting and repair.?
Patrick
---------- Post added at 10:54 AM ---------- Previous post was at 10:34 AM ----------
Also the manual doesnt mention an oil filter and Ive been unable to find one.
Old 05-28-2011, 04:05:02 PM
Default Re: Caterpillar 22 oil change
Found some nice info on this site, http://www.tractordata.com/farm-trac...wo-engine.html, including capacities for oil, trans, ect.
Old 05-29-2011, 01:59:15 AM
Deas Plant Deas Plant is offline
Hi, Nevr-Enuf-Stuf.
As far as I know the 22's did come with an operator's manual and a maintainence manual. There was quite likely a workshop manual for them too but that would not normally have come with the tractor but would have been issued to Cat dealers. It would have been available to owners to purchase, either from the dealer or from Cat direct.
You could try keeping an eye on 'flea'-bay and/or other sites, Craigslist f'rinstance, for these manuals or post a query over at ACMOC for information regarding re-prints.copies of them.
If my memory hasn't decided to go on strike, the 22's did run a 30 grade non-detergent engine oil.
Hope this helps.
You have a wonderful day. Best wishes. Deas Plant.
The Following User Says Thank You to Deas Plant For This Post:
Old 05-29-2011, 10:45:26 PM
I had found the operators manual online, http://www.angelfire.com/home/cat22/book/manual.html, copied it to file, the only thing the online version doesnt show is the fold out photo of a Twenty Two and its lubrication points. I also found out that there never was a "shop/repair" manual for the Twenty Two but that there was one for the Small Model Twenty and that it can be used for the Twenty Two. I joined the ACMOC, loads of great info.
Patrick
Old 05-30-2011, 09:37:08 AM
Rick Keane Rick Keane is offline
I have used 30 non detergent in my 22 for years with good results.
Good Luck
Rkeane
The Following User Says Thank You to Rick Keane For This Post:
Caterpillar 22 Trevor22 Dozers and Crawlers 2 02-20-2011 06:28:45 PM
Caterpillar 6point9diesel Dozers and Crawlers 17 11-01-2010 01:25:05 PM
Change out speed change lever IHC LA 3-5hp engine Stevie Antique Gas Engine Discussion 1 02-15-2010 01:43:47 AM
Caterpillar 50 smtwins Dozers and Crawlers 8 11-25-2007 08:11:25 PM
Caterpillar help Ivan Antique Engine Archives 3 03-11-2004 11:52:14 AM
