10 hp M IHC grinding corn
Tom Fleming
Take a closer look at the base......it is 2 parts. Also, look at the mag and igniter trip setup. That is a 10 HP. :brows:
oldironcollector
Definitely a 10 but that must be a pretty large mill, makes the engine look smaller I think. Optical illusion I guess.
DustyEngine
I'm pretty sure it is a 30 inch mill, the hopper was stopped up because we were trying to regrind some corn ground in another mill to run it through the bolter. The other mill did not have a bolter.
