1956 Lincoln SA200 40 Volts?
nick c
On the face plate it says, 1400 rpm, 40 volts, where do I check for 40 volts? My welder engine is completely rebuilt and I love it.
thanks nick c
Vanman
Should be at the welding lead output terminals. 40 volts will be the arc voltage though. The open circuit voltage will likely be something like 75 ~ 90 volts.
