20 hp Bessemer cooling system
Andrew Mackey
Re: 20 hp bessemer cooling system
For thermosyphon cooling, be sure to ramp the outlet from the top of the cylinder, up to the top of the tank, and the return down from the bottom of the tank, to the bottom of the cylinder on the engine. If water is pumped to the barrel, then you don't have to ramp the piping. Minimum pipe diameter, 11/2", 2" is better!:eek:
Rod Fielder
i'll send you a photo as soon as i can get to my camera
rod
Farmer John
I was going to run 1" on my 20 hp south Penn. is that to small ?My 12 hp Reid has 3/4" and it cools fine...thanks John
Rod Fielder
ok, what should the oilers be set at.(how many drops):shrug:
start at 10 per minute and if it is showing too much turn it down a bit. i run most of mine at 6 per minute
---------- Post added at 06:11 PM ---------- Previous post was at 06:06 PM ----------
1" will work ok john. i usually run 1" on all of mine that just run for the noise of it. in the field, most of the working engines that i remove are 1 1/2" to 2"
---------- Post added at 06:15 PM ---------- Previous post was at 06:11 PM ----------
you can control the temp of the engine by the incline of the pipe from the top of cylinder to the top of the barrel. i have seen some non working engines with the pipes run level to keep them running hotter.
Farmer John
thanks Rod as i had over half of it plumbed already i sure didnt want to do it over......john
Rod Fielder
there is about 12 different greens that i have had. pick one. the first 1000 bessemers weren't painted. i have one of them. most guys like the hunter green from tractor supply. it will fade after a year or so, even with their catalyst, but if you spray some oil on it and blow some dirt on it you won't even notice the color.
Kirk Taylor
Tie him fast and make him earn his keep!!!!!!
No worries, Kyle. They are like you; when I show up, I am slave labor. They even rent me out to the neighbor.
Actually, it's a cool place to go hang out for awhile. They have plenty of awesome toys and are fun to be around. I need to visit more often.
Kirk
