4000W Generator Troubles
smallen
small red/blue is the dpe winding
this rectifier assembly cannot be tested accurately with ohm meter
there is more in it than just a bridge rectifier
if you ohm it from the dc (large term)to the ac(small term) you will read about 20 meg ohm one way and about 1 meg ohm when you reverse the leads
new rectifier is # 66850gs $56.40
BTPost
Staff member
70
If there is more in there than what I drew, show us what is in there, and I will update the drawing for the forum and add it to the Archive.
jgarrett
i checked the dpe wires while flashing and got 30ish volts red to blue
hooked the rectifier bridge back up and still got 6ish volts blue to gray
smallen
http://www.jackssmallengines.com/help.cfm
use the original parts lookup on the left, it has the wiring diagrams
the service manual can be ordered from any briggs dealer, if you want the manual part number i will post it tomorrow when i get to the shop
the rectifier assy. has surge protection built in it ,mov,resistor and another diode
