6 cylinder "T" head engine needed
Alan D.
I am looking for a "T" head engine, Wisconsin or other with a CID of 450 to 600. If you know of any engines like this, Wisconsin or other, drop me a note.
Al
Alan D.
I would also consider other engines, Continental, Lycoming, Sterling, ETC "F or "L" head design.
Al
Mark Schneider
Here is a disassembled 1936 dual ignition Waukesha 6RB176 flathead 5 x 5 3/4 out of a fire truck. Almost appears to be an aluminum block and pan?
https://www.ebay.com/itm/Fire-Truck...547701?hash=item1a7778afb5:g:B5sAAOSwIQdZMYnV
Being apart isn't the worst as a thorough engine inspection can be done before the commitment to buy. I suspect that the owner found that parts were either very expensive or unobtainable. Be sure all the parts are there....:uhoh: !!
tharper
Alan,
With the completion of the Locomobile nearly there and the speedster in the pipeline are you looking for yet another project? (LOL)
I think the big T-head bug has bitten you rather deep!
T.
Alan D.
Hello Andrew, I had not thought of a V-12, but hmmmm, maybe. I need to know the length from the front of the fan to the back of the cylinder blocks. I also need to know how much frame width it will take to set this engine into for a fit. How much does this junior 12 weigh? What is the condition and money wanted? The CID is just about what I want. If all else works, I may bite on it! Of course pictures are always good.
Al alsfarms@hotmail.com
---------- Post added at 02:27:19 PM ---------- Previous post was at 02:22:01 PM ----------
Hello Terry, Your comments above show a pretty good shadow. I do enjoy the aspects of "T" heads but also all old engines. I am, however, staying very focused on the current Locomobile (1) then the Wisconsin (2). The trouble is I sometimes get confused about which is which! :)
Al
