Additional info for dcamp
Peter Holmander
71
dcamp: I am going to run the Reid for display purposes only. Engine speed will be a slow RPM. I was going to use some brand new 1/2 inch rubber air line for the connections, but if you think I need to go to a larger diameter hose, I can do that. Will be running the engine off a Wico OC magneto so no need for a second feed line to a hot tube. Will be using a 40lb brand new propane tank. I think that is all you asked for. If not, let me know through this post. Thanks
