Another Project
ronny p 148
Well Jim’s small engine repair rebuilt this carb and i found a oil bath air cleaner I don’t think is a brigs but it will work but there’s play in the elbow ! How can I correct this easily and no I don’t have a machine shop vid of problem here if I can get it here !
---------- Post added at 12:19:03 AM ---------- Previous post was at 12:16:23 AM ----------
Well try again on vid
---------- Post added at 12:42:02 AM ---------- Previous post was at 12:19:03 AM ----------
Having trouble with elbow on carb that attaches to air cleaner I can’t post picture for some reason it won’t let me but this aluminum elbow attaches to carb with two screws in bottom how can I stop the play where it slips over carb ? This is a 6 S Briggs
Ogrebeast64
Once they get a little age on them, they kinda flop a bit. I have the same issue on my Model 8. It's just pot metal. Maybe try slipping it over a couple of thin o-rings before bolting it back together.
ronny p 148
Fixed the elbow two wraps of electrical tape then slid elbow on righted it and it’s ok we’ll see if fuel and heat affects it !!
