Bean Engine
Eric Schulz
Something you don't see every day, a small engine made by Arem Bean. Nothing I can find on Mr Bean, like what country? Are there more around?
Eric
AussieIron
Re: Bean engine
Eric,only "Bean" named manufacturer I know about was associated with New Way motor company.
They had New Way engines on their sprayers. Have it in the back of my mind that they had their own brand engines on their sprayers as well. Here's a poor quality picture I found a while ago while researching the New Way company. I believe they are New Way engines in the photo. Just a possibility.-Cheers -Neil.
Eric Schulz
Thank you gents for your comments. Because I could find no mention of Arem in the Bean spray pump history, I thought them to be unlikely.
This engine, which belongs to a friend, looked home made to me too. But, the main components are castings, so though it possible that it was found with a lot of original bits missing, which have since been fabricated.
Eric
Winchester
I have friend here who has two Bean motor cars ......I think there is a version of the engine that was produced by Meadows . No idea if they made stationary engines
Scotty 2
I saw that at Bendigo, looked more like something someone had spent a lot of time fabricating?
Hello all
My first thought was a model someone has made. Many a kit has been made since the 1920's.
What number is on the plate Eric?
When you look at the engine, it's a high maintenance bit of kit. Chain driving the governor, buzz coil ignition with some fancy looking points behind the flywheel, the hit/miss linkage and the way the piston comes out the back of the block seems unusual. The way that cylinder is mounted underneath and the method of holding the engine down to the board also seem a bit flimsy. A brass or bronze inlet holding the inlet valve (valve cage) doesn't lead itself to a long serving engine. All signs of an engine that been 'made up'. In saying all that it is a great little engine I reckon. It would be a lucky person who owns it. Very lucky indeed. :)
What diameter would the flywheels be? They look familiar to me (minus the built in crank handle)
Cheers Scott
Ret AF
I read somewhere that Bean and Cushman started out as partners, but Bean eventually went his own way? If I can find the article, I'll post it here.
