Briggs Model Y Spark Plug Wire
Cnew
I’ve got a Briggs model Y that I just got to fire this afternoon but noticed shortly thereafter that the spark plug wire is nearly severed in half. Anyone know where to get a new wire or a high quality reproduction?
Ray Cardoza
34
get a couple feet of Copper cored wire. not the modern carbon wire. pretty much any autostore should have it
Brian Lynch
Yeah, the 7mm copper core wire does the trick. Strip off about a half inch on the end that will be on the coil. Take some solder and tin that end. Here's why- Trying to solder the wire onto the terminal will cause damage to the coil windings. Thread your tinned end through the coil terminal and bend it around the terminal. I put a small amount of silicone sealer over that connection to prevent flash over.
Cnew
Thank you both for the recommendation and tips on installing to the coil, that’s great insight to know ahead of the operation!
