Briggs & Stratton Model 14 carburetor
VP48
New member
I have just purchased a Simplicity Walk Behind Tractor with a HP Model 14 B&S engine. The carburetor is part # 291273.
The nozzle is damaged and apparently it is no longer available. However, I can get a carburetor overhaul kit which included the nozzle on ebay.
The trouble is that the threads in the lower carburetor body are damaged so that the needle valve retainer doesn't stay tight.
Apparently this lower body is available for $35 plus shipping.
I then wondered about getting a whole new carb, but it also is no longer available. I can get one on ebay (390323) that looks like mine, but doesn't say it replaces 291273.
So, I was wondering if anyone knows whether this 390323 carb will work for me?
Secondly, is there a method for repairing the threads in the carb body to accept the needle valve retainer?
Thank you for any assistance you can provide.
Partsman
Card Sponsor
The 390323 carb is the same except for the throttle shaft. The arm for the governor shaft points the wrong way. If you put your throttle shaft in it it will work. If you don't change the shaft your governor will not work it will be backwards. The threads in the carb are 5/16 32, I no of no repair kits for them. Briggs sells the taps so you can tap them but if they are to far gone there is nothing you can do. Jim
VP48
New member
Hi Jim
Thanks for your reply. It seems that the best way for me to go is to buy that carburetor then. I had been thinking that even if the lower carb body was the same I could just replace that.
Vern
VP48
New member
I have just received my new carburetor from China. Besides the throttle shaft being the other way around, I notice that the throttle valve and throat are larger than on my old one. Does this matte? They look like they are the same diameter, except that my old one has a sleeve in it that is about 1/16 inch.
If the larger bore makes a difference, I can go the other route and swap the needle valves and lower bowl, but I would prefer to replace the whole unit.
My engine is 5HP while I believe the replacement carb is really for a 7HP engine, though I may well be mistaken about this.
Shawn76
New member
Hey there I know this post is old, but how did the carb work for you ?, I just ordered the same carb for my Briggs model 14 . And fingers crossed it will work
EvilDr235
Member
Some or maybe all the China replacement carbs have metric threads for carb mounting. The other threaded holes and bolts maybe metric also. As far as the main jet threads----------------- ?
