Caterpillar 15 Manifolds
Detroit Guy
I'm in need of the manifold assembly for a Caterpillar 15. Is it specific to the 15 or are there other models it will interchange with? Ideas where to find the assembly?
Bruce
BoilerGuy
Be aware there are 2 different Fifteen's Serial numbers that start PV are known as the big 15 and were common, thousands were made, I believe that is what rosewood sells manifolds for. Small 15 serial number starts with 7C, they have a lot in common with a Cat 10
