Chinese Four wheeler.
Jesse Zilafro
I have 300 4 wheeler that I can't get to idle right, it either idles to fast if I slow it down it will stop running.
Thanks Jesse Z.
ulgydog56
going to be a carb issue, take apart and make sure low speed jet is cleaned out not plugged also check for vacuum leak to intake manifold and tube from crankcase....
I like oldstuff
You might be at the point the engine is on the advance curve and speeds up. Careful tinkering of the adjustments will get it right.
*But first, you may have a gunked up low speed circuit in the carb. Take the carb apart and clean out everything.
