Compression tester lister petter
jim delong
I have a lpa3 diesel mower and am suspicious about my compression. Does anyone know of a compression tester product that I can buy that fits in an injector hole (no threads) and is held down by a fork rod. The diameter of the injector is c. 17mm.
cobbadog
There are multi fit compression gauges to suit diesel engines and one of them will have the adaptor to suit. I noticed the difference when buying a gauge for the TVO tractor and only then did I read closer about fittings and accessories and basically you will buy a gauge for petrol engines like mine or a diesel kit. As this is something I don't make a living from I settled for a middle of the range model and it works well and once you have one it is amazing how often you want to know what compression it is running at.
PFT
jim, have you found an appropriate adapter yet? I might be able to make one if you wanted to run up I25 to exit 255. I am just north of the exit on the Frontage Rd. Thompson River Ranch subdivision.
