Computer RAM
Bill Sherlock
75
I have a MacBook Pro purchased in 2010. It came with 160 GB hard drive and 2 GB RAM. I since installed a 960GB solid state hard drive and would like to increase RAM capacity as appears I need it for some applications. I've been led to believe that 8 GB RAM was maximum I could have in this computer so bought an 8 GB memory card.
Since purchasing the card I have learned that there are 2 cards in the computer which are 1 GB each. One set of instructions I found indicates that it is better to use 2 cards instead of one.
Now my question is do I return the 8 GB card and buy two 4 GB cards or will it be OK to buy a second 8 GB card and install them both. I have confirmed that the 8 GB card will fit in the computer.
Bill
Power
Well, I have only worked on a handful of Mac's, but have a fair amount of PC experience. Generally, if your MacBook pro has an intel core 2 duo 2.4 GHZ or higher, it can address 16 GB of ram, even though Apple advertises 8 GB. Any Macbook Pro model 7,1 or higher, and any Mac Mini model 5,1 or higher should be able to use up to 16GB of RAM.
On a PC, the first thing is to verify the maximum amount of RAM the motherboard supports.
Then find out the maximum RAM speed and type the motherboard can handle. I.e. 1066 MHZ, 1333 MHZ, 1600 MHZ......... Yours might be able to take 1600 MHZ DDR3.
We find RAM speed to be as important as the amount of ram. You want to know if your motherboard supports interleaving, which can boost speed 8% or so.
Quality of the ram is critical for successful operation. You want error free RAM with no dead cells. Buy only name brand.
For more information---
How much RAM can my MacBook Pro accept | MacRumors Forums
forums.macrumors.com › Macs › Notebooks › MacBook Pro
Sep 5, 2012 - How much RAM can my MacBook Pro accept. the specs are in the image.
Also:
OWC MaxRAM Memory Certification
Get up to double the amount of RAM than factory supports
Fully tested and Certified to work properly.
Why Buy OWC Brand Memory?
•Meets or exceeds manufacturer specifications.
•Rigorously in-house lab tested to ensure superior quality, compatibility and reliability.
•Backed by industry leading lifetime advanced replacement. If you need your OWC memory replaced, we will ship to you same day.
OWC MAXRAM logo The OWC 'MaxRAM' Certification Program determines the maximum amount of memory that can be installed in a Mac as validated by a series of comprehensive, in-house laboratory tests. While OWC "MaxRAM" configurations exceed Apple's officially supported maximums, all OWC brand memory upgrades are assured to perform flawlessly and are covered by a Lifetime Advance Replacement Warranty and Money Back Guarantee.
Below is a list of Macs that have been OWC MaxRAM Certified to be capable of utilizing up to double the memory than Apple specifies. You can also view all of OWC Memory options for all computers.
Mac Pro Apple Mac Pro
Factory Supported OWC Tested & Certified
Mac Pro August 2006 - View Memory Options
Apple 16GB Actual 32GB
Mac Pro April 2007 - View Memory Options
Mac Pro January 2008 - View Memory Options
Apple 32GB Actual 64GB
Mac Pro March 2009 'Quad-Core' - View Memory Options
Apple 16GB Actual 48GB
Mac Pro March 2009 '8-Core' - View Memory Options
Apple 32GB Actual 96GB
Mac Pro Mid 2010 'Quad-Core' - View Memory Options
Apple 32GB Actual 48GB
Mac Pro Mid 2010 '6-Core' - View Memory Options
Mac Pro Mid 2010 '8-Core' - View Memory Options
Apple 64GB Actual 128GB*
Mac Pro Mid 2010 '12-Core' - View Memory Options
Mac Pro Late 2013 - View Memory Options
MacBook Pro MacBook Pro
MacBook Pro 15" Late 2007 - View Memory Options
Apple 4.0GB Actual 6.0GB
MacBook Pro 17" Late 2007 - View Memory Options
MacBook Pro 15" Early 2008 - View Memory Options
MacBook Pro 17" Early 2008 - View Memory Options
MacBook Pro 15" Late 2008 Unibody - View Memory Options
Apple 4.0GB Actual 8.0GB
MacBook Pro 17" Late 2008 - View Memory Options
MacBook Pro 13" Mid 2010 - View Memory Options
Apple 8.0GB Actual 16.0GB
MacBook Pro 13" Early 2011 - View Memory Options
MacBook Pro 15" Early 2011 - View Memory Options
MacBook Pro 17" Early 2011 - View Memory Options
MacBook Pro 13" Late 2011 - View Memory Options
MacBook Pro 15" Late 2011 - View Memory Options
MacBook Pro 17" Late 2011 - View Memory Options
MacBook Pro 15" Mid 2012 - View Memory Options
Bill Sherlock
75
I decided to go for installing two 4GB RAM cards for total of 8 GB RAM. Couldn't find any 4 GB RAM cards in North Battleford at 5 locations I checked! Landed up at a computer store in Saskatoon and purchased them yesterday at a cost of $76 including taxes. Should be good enough for what I use my computer for.
Bill
