Delco Light Plant
Slimfinnish
Does anyone know what kind of ignition points they use. Im having trouble with my Delco generator burning points. Thanks Leonard
cammer
i used the complete ignition plate from a 390 ford engine looks original . youtube restored delco light plant and both running it,s on one of them
Mike Schweikert
53
Early Lincoln and Packard used very similar points
That is what I used on my 752
Mike
44dwarf
My 4b12 was drilled and taped to take ford tractor points i just had to cut off the tab on the backing plate that holds the connection point for the coil wire. Change the condenser and add a ballast resistor from a 60's points fired MOPAR will make them live longer. The resistor goes in the +12v wire to the ign coil.
