EB6500 Honda Generator
ziggyco
The fuel solenoid will not work. I've replaced it. I have power to the starter, but when I hit the key, the solenoid will not open. I've tested the new solenoid and it works. Any Ideas? Do I have a bad starter switch?
radiodoc
I would test for voltage at the solenoid with a test light or voltohm meter. If no voltage, then check where the lead to the solenoid comes out of the switch.
ziggyco
Ck'd lead's from switch and no juice. So I'm guessing bad switch. Any other ideas besides the switch? Thanks Ziggy
radiodoc
Ziggyco the CRC electronic cleaner Stringj mentioned would be worth a try. It can be had at Walmart or most auto parts stores.
