electronic ignition
Alan R
76
Is there a module that I can use in a double magnet flywheel situation. This is for a 1960 Briggs 5.5 (?) hp engine. Why do the number of magnets make a difference?
Thanks,
Alan
Andrew Mackey
Re: electronic ig
B&S used to make a Magnetron Module converter for the earlier magnetos, but I do not know if they are still being made. That engine has a 3 pole mag, held with 4 bolts - correct? The magnets in the flywheel are weaker, and the spacing is different.
Alan R
76
Re: electronic ig
Thanks, Andrew. Correct about 4 bolt coil. Back to the drawing board.
Alan
K D Redd
The STEN'S Mega-Fire module will do what you are looking for. The B&S Magnetron WILL NOT work with the Briggs coil that uses four mounting screws.
Kent
John Newman Jr.
64
Try Pete's Small Engine Parts. www.psep.biz
One nice thing about them is they charge a flat rate for shipping no matter how much you buy (I think it is something like $5.95)
