Engine & gen. set made in Germany?
mechman
Goodday I bought this in Ireland a few. years ago & need help with make & any information as I'm making it a winter project this year! The carb is a all brass updraft made by Cudell motoren Ges Berlin N65 & the mag looks like a Bosch? having a small problem. getting out of its mount. It has a ported exhaust & it's own separate fuel & oil tank that came with it. The cooling fan is flat belt driven from a pulley on the gen. end of the unit Any & all help appreciated! Larry Healey
mechman
Thanks for the reply--I think it's older than that because of the flat belt fan drive & The ported exhaust! Larry
mechman
Go the mag off--not a make I have seen before---make is A U other info is A1 # 12364
on side of brass points cover stamped AUS--I'm guessing Austria??? made Larry
