Essex Hot Air Engine
Brian.P
I bought this engine years ago it was missing the disk and the connecting rod
need to make a base and burner and age the rod runs not bad just have to time it a little more
would it have had the water tank at the end for cooling
thanks to woody sins for the measurements
https://youtu.be/U-GOCfoEPsQ
Brian.P
I added this tank a couple of weeks ago
it ran with out it but should run at a lower heat on hot days
this one never had a tank as there are no holes for the screws and no grove in the flywheel for a fan
when I have the time I will be adding something to run off it
deverett
Seeing your original engine, it just goes to show what a good job MyfordBoy did of copying the design.
I've got a turntable for mine, but haven't hooked it up yet.
Dave
The Emerald Isle
Brian.P
He does great work
I ordered the turn table casting today will have it ready for next year
there isn't many little hot air engines here the 2 shows I had at this year always had someone looking at it
will be nice with the turn table with some old toys on it .going to make a 24 to 30 '' wood top
deverett
He does great work
If you give me your email address, I'll send you a picture of my engine hooked up to the turntable. I can't attach a picture directly here.
Dave
The Emerald Isle
