Fairbanks Morse model H 6hp needs help
Jim Gauer
Anyone know of a running F/M model H 6hp with throttle governor which originally started on gasoline and ran on kerosene.
I would like to talk to the restorer, possibly hear it run or visit. The H is not built like a Z. The H came before the highly produced Z.
I own one that is not running properly
I am located in Northeast Ohio just south of Cleveland
Jim
Doug Tallman
Are you trying to run it on kero or gas only? Most won't run good on kero unless you are working them hard. Most just run them on gasoline. What kind of a problem are you having?
Turbo
I have one that runs perfect. PM me and I can give you my phone number if you want to talk.
Preston Wells
59
Here is my 6H. I do run this engine about 1/2 choked. These are great running engines when you get them dialed in. You can PM with any questions.
Kevin O. Pulver
Email NOT Working
54
I bought a basket case 4horse kerosene burner that should be a Magneto charge away from running now. I would like to find a crank guard for it.
Recast is fine. If anyone can help I'd sure appreciate it. I'd prefer one with a magneto mount on it.
Jim Gauer
I run it on gasoline, the carburetor has a starting side to run on gas and a running side that uses kerosene pumped from the fuel tank
The gasoline side of the carb does not work so I run gasoline in what would be the kerosene part of the carburetor.
It runs geat at 350rpm. It misses, runs rough on the 200-250 range
Starts great, accelerates great, runs rough at slow speeds
Tried all types of ignition timing.
I feel it is carb problem. Sunk in mud on farm outside for 50+ years
Carb frozen with water and we welded during restoration.had no pictures of carb or throttle plate. Acts like at low speed fuel is not atomizing properly
Idea are welcome. Know of any H Model 6 hp carbs or H engines for sale
Zach Nagel
The valves should be a snug fit it their guides and the springs in good condition especially the exhaust. If your engine is missing the intake valve cover, be sure to plug the screw holes in the head as 1 or 2 go right into the intake passage and will cause a loss of vacuum. I time the ignition late on a loafing show engine. As far as not running on the gas side, there is a check valve in the bottom of the carb on that side that is usually stuck. Its part # 603h in the pic above the hopper. The butter fly is also pictured, it should have a small notch that is in line with the fuel nozzle that sticks out of the back of the carb.
Jim Gauer
We think it is a 1914
Thanks for picture of carb that is my carb.
I know of no check valve but I will check - carb was welded up
It was damaged badly
How slow does your engine run ?
Thanks for info
Zach Nagel
My engine will run fairly slow, i'd guess under 200 rpms and runs smooth but it has to have the choke set just right. Also a hot spark. You might try running on a battery and coil and see if that helps. Mine runs better on a battery but I'm working on getting it better on the mag.
Bill Trainor
My 6hp will run real nice down to about 150 rpm on the battery. It wont run on the mag much below 180 rpm. I also run on gasoline on the kero side. My fuel nozzle was missing when I started, so I had to experiment with different lengths and angles, which both made a difference. Great running engines.
